Range: 0 miles
Range: 0 miles
My car is parked at the station with the range meter reading zero. Will I make it to 2 miles to the petrol station?
My XKR used to do 30-40 miles on zero but I suspect German efficiency may mean that zero means zero...
Phantom Black '06 RS4 Saloon
Recaros, loaded (except ceramics & bluetooth).
RE: Range: 0 miles
2007 Daytona RS4 Avant
RE: Range: 0 miles
Thanks, my searching skills clearly aren't very good.
This was interesting though:
Will try that tonight.Nickm wrote:I can get about 68 litres in mine! I use the button inside the filler entrance to release the air and allow more petrol! You can get about another 5 litres after the pump has stopped!
- PetrolDave
It should be just inside where the fuel nozzle goes in, if the same as the B5 - looks like a rubber bit on the left
You should be able to pull your nozzle out slightly and push it with the fuel nozzle, then return the fuel nozzle to re-fill that extra bit
FYI - just the other day I was at 0 for 20 miles before refuelling my B5 RS4... was pretty scary though as I would have been VERY stuck if I ran out...
MB
MB
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
Marcus-RS4
Users browsing this forum: No registered users and 129 guests
