Range: 0 miles
theaxe
Range: 0 miles
Post by theaxe » Wed Apr 02, 2008 10:37 am
My car is parked at the station with the range meter reading zero. Will I make it to 2 miles to the petrol station?
My XKR used to do 30-40 miles on zero but I suspect German efficiency may mean that zero means zero...
Phantom Black '06 RS4 Saloon
Recaros, loaded (except ceramics & bluetooth).
Dom81
RE: Range: 0 miles
Post by Dom81 » Wed Apr 02, 2008 10:51 am
Think you should be OK - have a look at this
http://www.rs246.com/index.php?name=PNp ... ic&t=67688
2007 Daytona RS4 Avant
theaxe
RE: Range: 0 miles
Post by theaxe » Wed Apr 02, 2008 10:53 am
Thanks, my searching skills clearly aren't very good.
This was interesting though:
Nickm wrote:I can get about 68 litres in mine! I use the button inside the filler entrance to release the air and allow more petrol! You can get about another 5 litres after the pump has stopped!
Will try that tonight.
P_G
Post by P_G » Wed Apr 02, 2008 11:13 am
If just gone to 0 then you'll easy get another 10 miles out of it, there is IIRC a 3 litre reserve.
I've never found this hallowed 'button' though.
PetrolDave
Post by PetrolDave » Wed Apr 02, 2008 11:19 am
P_G wrote:I've never found this hallowed 'button' though.
Nor me - all I can find is the rubber buffer stop against which the filler flap rests when closed, and that can't be pressed in...
P_G
Post by P_G » Wed Apr 02, 2008 11:48 am
I'm glad it's not just me then.... :lol:
mbelle
Post by mbelle » Wed Apr 02, 2008 12:09 pm
It should be just inside where the fuel nozzle goes in, if the same as the B5 - looks like a rubber bit on the left
You should be able to pull your nozzle out slightly and push it with the fuel nozzle, then return the fuel nozzle to re-fill that extra bit
FYI - just the other day I was at 0 for 20 miles before refuelling my B5 RS4... was pretty scary though as I would have been VERY stuck if I ran out...
MB
Marcus
Current: A C6 Audi
Previous: A B5 Audi
dom888
Post by dom888 » Wed Apr 02, 2008 12:34 pm
I've been told to change the petrol filter once this has happened.
Marcus-RS4
Post by Marcus-RS4 » Wed Apr 02, 2008 12:43 pm
The button is there - it is just inside the filler neck, on the left hand side, a little metal slider - makes you look a little strange at the pumps though ;)
Dom81
Post by Dom81 » Wed Apr 02, 2008 1:33 pm
I found the button too. Never used it while filling, but had to reassure myself that it was there!
JohnW
Post by JohnW » Wed Apr 02, 2008 1:45 pm
I regularly go '-20' in my B5 RS4. I have run out once, and that was around 28 miles, plus an uphill climb. When your about to run outyou will hear the pump whine much louder than it normally does. Even when this starts you have a couple of miles left. ;)
Too many toys, not enough time
Nickm
Post by Nickm » Fri Apr 04, 2008 8:56 pm
The button is good! I am getting 330miles out of a tank by pressing it! Makes your finger dirty though!!!!!!!!!!
Users browsing this forum: No registered users and 202 guests
