novice vagcom
jay1974
novice vagcom
Post by jay1974 » Mon Mar 10, 2008 7:56 pm
i dont have VAG-COM myself,but my missus cousin has it,he is a mechanic but is used to working on volkswagens,instead of paying stealers rates for diagnostics,would i be safe asking him to do my rs4 b5,if i have problems in the future.can he balls anything up for instance if he is not familiar with using such equipment,on such a high performance car,i do no he remaps diesels.any advice please j
derdle
RE: novice vagcom
Post by derdle » Wed Mar 12, 2008 1:44 pm
Well, I suppose that he might delete fault codes that ought to be investigated and rectified..which if left unrectified could become more serious later.
There is an old saying - "Don't mess with things you don't understand" (unless you can afford to unmess it???).
PetrolDave
Re: novice vagcom
Post by PetrolDave » Wed Mar 12, 2008 6:04 pm
jay1974 wrote:i do no he remaps diesels.
He won't be doing that using VAG-COM, because VAG-COM doesn't offer re-mapping - only checking and setting some of the parameters used by the existing maps.
Not sure I'd be 100% happy letting him loose on my car ...
Dom81
RE: Re: novice vagcom
Post by Dom81 » Fri Mar 14, 2008 10:23 pm
My thoughts too - sometimes a kind offer is best avoided...
2007 Daytona RS4 Avant
dssean
Post by dssean » Sun Apr 06, 2008 4:52 pm
if he uses Vag Com on vw's and is pretty confident in himself then aslon as he does'nt delete or change anything ( its pretty straight forward ie sticking to BASIC FUNCTIONS on Vag Com) then he should be ok. saying that Vagcom is'nt all you need to do correct diagnostics . it only points you in the right direction. a scope and alot of understanding car electronics will be the only real way to fully understand what the dtc's are pointing at..
Return to “DTC / VCDS”
