novice vagcom
novice vagcom
i dont have VAG-COM myself,but my missus cousin has it,he is a mechanic but is used to working on volkswagens,instead of paying stealers rates for diagnostics,would i be safe asking him to do my rs4 b5,if i have problems in the future.can he balls anything up for instance if he is not familiar with using such equipment,on such a high performance car,i do no he remaps diesels.any advice please j
RE: novice vagcom
Well, I suppose that he might delete fault codes that ought to be investigated and rectified..which if left unrectified could become more serious later.
There is an old saying - "Don't mess with things you don't understand" (unless you can afford to unmess it???).
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin
If you dont "do it now" you never will.
Huge Grin
- PetrolDave
Re: novice vagcom
He won't be doing that using VAG-COM, because VAG-COM doesn't offer re-mapping - only checking and setting some of the parameters used by the existing maps.jay1974 wrote:i do no he remaps diesels.
Not sure I'd be 100% happy letting him loose on my car ...
RE: Re: novice vagcom
My thoughts too - sometimes a kind offer is best avoided...
2007 Daytona RS4 Avant
if he uses Vag Com on vw's and is pretty confident in himself then aslon as he does'nt delete or change anything ( its pretty straight forward ie sticking to BASIC FUNCTIONS on Vag Com) then he should be ok. saying that Vagcom is'nt all you need to do correct diagnostics . it only points you in the right direction. a scope and alot of understanding car electronics will be the only real way to fully understand what the dtc's are pointing at..
Users browsing this forum: No registered users and 62 guests
