CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!!!!!!!!!!!!!
ZKNY
Post by ZKNY » Thu Feb 21, 2008 7:08 pm
hey guys,
i came across this. its an intake manifold for our car. it looks stock, but is far from it. it is lightly ported, and has a much larger plenum. this will give the car way more air upstairs, where it is normally choked off.
take a look, i have a one-off model myself. you cannot find this anywhere. get it here first. if anyone has any questions, pls email or PM me.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 33105&rd=1[/url]
dummi
RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!!!!!!!!!
Post by dummi » Thu Feb 21, 2008 7:35 pm
how much boost have you run with it so far?
s4woody
Post by s4woody » Thu Feb 21, 2008 7:58 pm
and what happens to the AUX water pump with all that extra depth..
GARTH ROAD MOT CENTRE LTD
020 83353032
ZKNY
Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!!!!!
Post by ZKNY » Fri Feb 22, 2008 8:59 am
s4woody wrote:and what happens to the AUX water pump with all that extra depth..
great question. it is either re-located. or better yet, removed!
DavidT
RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!
Post by DavidT » Fri Feb 22, 2008 9:45 am
Moved to tuning & mods my me so everyone can see it & so we only have one thread running.
MarkB
Post by MarkB » Fri Feb 22, 2008 10:13 am
I've been thinking about removing my aux pump. I've seen it mentioned a few times on Audiworld.
Does the extra plenum volume give any noticeable advantage?
Mark
tartan_rob
Post by tartan_rob » Fri Feb 22, 2008 10:46 am
I am working a carbon reinforced with kevlar custom intake manifold for MRC. Similiar to the std design but much wider ports and more direct intake + about an 1/8 of the weight....
2017 Kawasaki Z1000
2014 RS6
2014 S1
rikrose
Post by rikrose » Fri Feb 22, 2008 11:36 am
MarkB wrote:
ZKNY wrote:I've been thinking about removing my aux pump. I've seen it mentioned a few times on Audiworld.
I've been thinking about jumping off a bridge recently. I've seen a lot of people who own parachutes doing it, and they seem to have fun.
Is there a summary for the supposed benefits and losses in doing this, to save me having to search audiworld?
MarkB
Post by MarkB » Fri Feb 22, 2008 12:27 pm
rikrose wrote:
MarkB wrote:I've been thinking about removing my aux pump. I've seen it mentioned a few times on Audiworld.
I can't remember :(
Mark
confusionhunter
Post by confusionhunter » Fri Feb 22, 2008 7:40 pm
I am also interested to know what advantage expanding the plenum gives.... I personally dont see theoretically that it is any advantage. In fact its a disadvantage as if more volume to compress.... Unless the std plenum is too small (which it might be) Plenums are supposed to be the same volume as the displacement of the engine....
Mark.
s4woody
Post by s4woody » Fri Feb 22, 2008 8:29 pm
well you'd proberbly get an adrenalin rush..(benefit) then if ya parachute dont open <beep> yourself (losses)
hope that helps..
020 83353032
ZKNY
Post by ZKNY » Sat Feb 23, 2008 9:46 am
MarkB wrote: great question. it is either re-located. or better yet, removed!
yea, i removed mine. you just have to let the car sit a little longer if you run the car hard.
what do you think? =)
ZKNY
Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!
Post by ZKNY » Sat Feb 23, 2008 9:52 am
confusionhunter wrote:I am also interested to know what advantage expanding the plenum gives.... I personally dont see theoretically that it is any advantage. In fact its a disadvantage as if more volume to compress.... Unless the std plenum is too small (which it might be) Plenums are supposed to be the same volume as the displacement of the engine....
ding-ding-ding! somebody is on the right track!!! the stock plenum is too small. another reason why KO4's die off upstairs. with a larger plenum you have air all the way past the redline.
there may be a slight lag (200-500) rpms (depending on tune!!!), but once you get going, the tach will bounce off the redline. sooo much more air you wouldnt believe.
i know the gent who custom fabs em.
confusionhunter
RE: Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!
Post by confusionhunter » Sat Feb 23, 2008 10:49 am
yep.... having a look at the plenum yesterday there is no way that is 2.7 litres of volume.... lucky if its 1.5 litres!
A sacrifice of cramming too much in there I guess!
Mark.
tartan_rob
Post by tartan_rob » Mon Feb 25, 2008 10:01 am
Surely a smaller plenum equates to much more responsive boost as less area to pressurize?
Is it simply a trade off of responsiveness against high boost levels?
2017 Kawasaki Z1000
2014 RS6
2014 S1
Users browsing this forum: No registered users and 110 guests
