Fan assisted side mount intercoolers
I'm not sure if this has been thought about before but could you mount a high power fan behind each SMIC?
Mark
you'd have to move or junk the air-con canister on the drivers side IC as it's rite close behind that 1..and i dont think you'd get a fan behind it..
would the fan be blowing towards the front or sucking air through..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
where would you get a fan strong enough to help? water mister would be better, co2 or nos even better (but co2 is bad ofr intake and nos is a waste for cooling ICs)
aircon used to cool ICs?? I think some astons used to do that.
http://www.MRCtuning.com
But more efficientS4 wrote:people seem to think it has to go near the throttle body, not true.
Darren
Cheers,
Andiroo
WIP :to be advised.....
- tdiquattro
Burn cycle is key in this Darren IMHO. I did a lot of investigation into this in '03;
http://www.rs246.com/index.php?name=PNp ... pic&t=2791
With a spray system, I agree it does have benefits mate, but nowhere near as much as the direct route (well before tb) when we tried it. Plus with the spray system you have to work out what is the optimum time to spray which in some instances can be a bit later than needed i.e. the trigger for the spray. I tried both and stuck with the one that worked for me and my engine best
Cheers,
Andiroo
Cheers,
Andiroo
No mate, just a single drilled in at the junction of the Y pipe giving it plenty of time to get 'swirled and atomised' (so I was told). The key was the trigger which ended up being the '3 input hit' programmable Aquamist. Worked a treat, but make sure you get your car mapped with it turned OFF, otherwise if you run out of water......
Cheers,
Andiroo
Cheers,
Andiroo
Users browsing this forum: No registered users and 39 guests
