Fan assisted side mount intercoolers
MarkB
Post by MarkB » Sat Feb 02, 2008 5:46 pm
I'm not sure if this has been thought about before but could you mount a high power fan behind each SMIC?
Mark
Philws4
Post by Philws4 » Sat Feb 02, 2008 6:26 pm
Not sure on that Mark, but i like your thinking and can't see any reason why not!
B5 S4
s4woody
Post by s4woody » Sat Feb 02, 2008 7:19 pm
you'd have to move or junk the air-con canister on the drivers side IC as it's rite close behind that 1..and i dont think you'd get a fan behind it..
would the fan be blowing towards the front or sucking air through..
GARTH ROAD MOT CENTRE LTD
020 83353032
MarkB
Post by MarkB » Sat Feb 02, 2008 7:21 pm
Behind I'd want it to be sucking. Forgot about the AC canister :(
Mark
dazzer
Post by dazzer » Sat Feb 02, 2008 8:36 pm
MarkB wrote:Behind I'd want it to be sucking. Forgot about the AC canister :(
Interesting. Do you think it would make much difference? Reason why I ask is will it add any additional cooling over and above the air already passing through the air cooler as a result of the forward momentum of the car?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Feb 02, 2008 8:37 pm
where would you get a fan strong enough to help? water mister would be better, co2 or nos even better (but co2 is bad ofr intake and nos is a waste for cooling ICs)
aircon used to cool ICs?? I think some astons used to do that.
http://www.MRCtuning.com
s4woody
Post by s4woody » Sat Feb 02, 2008 9:33 pm
i think its an FMIC heat wrapped to aid in temps then..
020 83353032
S4
Post by S4 » Sat Feb 02, 2008 10:16 pm
deffo go for a decent meth/water injection..... on a lot of cars people mist it across the cooler.. people seem to think it has to go near the throttle body, not true.
Darren
Andiroo
Post by Andiroo » Sun Feb 03, 2008 12:19 am
S4 wrote:people seem to think it has to go near the throttle body, not true.
Darren
But more efficient :wink:
Cheers,
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
tdiquattro
Post by tdiquattro » Sun Feb 03, 2008 12:32 am
Don't Smart cars have fan assisted intercoolers?, sure I saw it somewhere...
Nige'
2000 silver S4 Saloon
S4
Post by S4 » Sun Feb 03, 2008 12:57 am
Darren
Cheers,
Andiroo
yes maybe on the burn cycle, but you would be surprised how much the intake temps drop, when it is blown across the IC
Darren
Darren
Andiroo
Post by Andiroo » Sun Feb 03, 2008 1:25 am
Burn cycle is key in this Darren IMHO. I did a lot of investigation into this in '03;
http://www.rs246.com/index.php?name=PNp ... pic&t=2791
With a spray system, I agree it does have benefits mate, but nowhere near as much as the direct route (well before tb) when we tried it. Plus with the spray system you have to work out what is the optimum time to spray which in some instances can be a bit later than needed i.e. the trigger for the spray. I tried both and stuck with the one that worked for me and my engine best :wink:
Cheers,
Andiroo
S4
Post by S4 » Sun Feb 03, 2008 1:33 am
Are you running a twin system into the bi-pipes? sounds good.
Darren
Andiroo
Post by Andiroo » Sun Feb 03, 2008 1:59 am
No mate, just a single drilled in at the junction of the Y pipe giving it plenty of time to get 'swirled and atomised' (so I was told). The key was the trigger which ended up being the '3 input hit' programmable Aquamist. Worked a treat, but make sure you get your car mapped with it turned OFF, otherwise if you run out of water......
Cheers,
Andiroo
s4woody
Post by s4woody » Sun Feb 03, 2008 1:02 pm
yes smart cars do have a fan on there intercooler..and its a tiny fan too
020 83353032
Users browsing this forum: Google [Bot] and 65 guests
