Coliovers?
Coliovers?
Just wondering how much firmer a coilover suspension (H&R Hopefully) would change the comfort of my 2000 s4, 98,000 and counting. Hope to lower it by about 20mm and fit 18" wheels.
Cover around 350 miles a week and i don't want to turn it into a race car, i use it every day.
RE: Coliovers?
The H&R coilovers are quite a bit softer than I thought they'd be so probably what you are looking for? I stiffened mine up with ARBs and they're now perfect (for me!).
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
You can still adjust the ride height once they're on noccy (that is of course if you want to) - it's the dampers that are fixed (they are KW dampers 'tuned' to match the Eibach springs) - KW are very good. The front coilovers are double spring too.
TBH if you only want to lower it 20mm see if you can get some used RS4 shocks/springs - IIRC these are lower than the stock S4 set-up - or some used Quattro Gmbh RS4 shocks/springs ... probably a fair bit cheaper than a new set of coily's.
But if you want to buy new kit then I can definitely recommend the Eibach's for performance and comfort - combine them with H&R thick-set ARB's, MRC's "custom" rear ARB stiffener, and some RS2 rear drop-links and you're well sorted!
Deus ex machina
Eibach c/o's ~£650, H&R ARBs ~£300, MRC rear ARB mod ~£28, RS2 rear droplinks ~£110 (or can get copies for less - rolskii got some, don't know how much for though) - then there's the labour to get it all fitted and adjusted - maybe ~6/7hrs? Don't quote me on that though, give Doug a call at MRC, he'll give you an estimate.
Deus ex machina
