Any ideas to maximise SMIC cooling on a RR with one fan?
Blue_Thunder
Post by Blue_Thunder » Tue Jan 15, 2008 4:01 pm
I'm booked into a RR at Awesome GTI which only has one fan, but i've got RS4 intercoolers on my S4.
They've told me it's a fierce fan which creates up to 90mph flow, but i've no idea how much area this will cover, ie: whether it will have a wide enough area to cover both ic's. I suspect not.
Can anyone suggest anything which may help aid the cooling?
Would angling the fan across the front of the car slightly (as opposed to facing it straight on) be beneficial?
Would it be better to just concentrate all the cooling on one intercooler?
s4woody
RE: Any ideas to maximise SMIC cooling on a RR with one fan?
Post by s4woody » Tue Jan 15, 2008 4:51 pm
if its a moveable fan then try not to have it too close..it mite flow more air through them that way..but im sure they no what there doing..
GARTH ROAD MOT CENTRE LTD
020 83353032
S4TAN
Post by S4TAN » Tue Jan 15, 2008 5:02 pm
Ask them if they can put a wedge shaped 'splitter' in front of the fan - dead in the middle, so it diverts the flow to either side of the car.
Deus ex machina
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Jan 15, 2008 5:07 pm
Seen this lots of times. waste of time mate. get them to watch the intake charge temp on the run. Did this on 5 different sets of rollers with my car had RS4 IC's. it will go through the roof... Can be done with VAG-com.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
S4TAN
Post by S4TAN » Tue Jan 15, 2008 5:15 pm
Yep - both times my car has been on the rollers the IATs went thermonuclear. Don't expect a realistic reading from the dyno with SMICs - add another 15-20bhp on to the dyno results for the open road.
Deus ex machina
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Jan 15, 2008 5:39 pm
Couple of years ago saw between 290bhp and 380bhp difference. LOL would run some logs of the intake temp on the open road before the day. then you can see if there fans are up to the job...
MING BLUE AUDI S4
Car is on Lock down
Blue_Thunder
Re: RE: Any ideas to maximise SMIC cooling on a RR with one
Post by Blue_Thunder » Tue Jan 15, 2008 5:48 pm
S4TAN wrote:Ask them if they can put a wedge shaped 'splitter' in front of the fan - dead in the middle, so it diverts the flow to either side of the car.
I had thought of nicking an old train snow plough!
BRETTCOLLINS wrote:get them to watch the intake charge temp on the run.
I was planning to do my own logging during the runs. Can high IAT's do any damage, or will the ECU just pull back the timing/fuelling to compensate?
BRETTCOLLINS
RE: Re: RE: Any ideas to maximise SMIC cooling on a RR with
Post by BRETTCOLLINS » Tue Jan 15, 2008 5:54 pm
On my car the ECU just backed everything off.
MING BLUE AUDI S4
Car is on Lock down
davs4
Post by davs4 » Tue Jan 15, 2008 6:32 pm
Brett did the IAT's improve after you fitted Water injection?
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Jan 16, 2008 9:47 am
When I was running RS4 IC's yes the water injection was a must, made so much difference. Still helps with the FMIC now too
MING BLUE AUDI S4
Car is on Lock down
Blue_Thunder
Post by Blue_Thunder » Wed Jan 16, 2008 3:18 pm
Any ideas of what sort of IAT's you need to be running before the ECU will pull everything back?
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Jan 16, 2008 4:12 pm
Sorry No idea......
MING BLUE AUDI S4
Car is on Lock down
Jarv
Post by Jarv » Sun Jan 20, 2008 11:52 am
If it's any use, at Thorney in November, my IAT's hit 90 deg, and that was with two movable fans directed straight into the standard side-mounts.
Mike
Q7
s4woody
Post by s4woody » Sun Jan 20, 2008 12:32 pm
time for an FMIC.. :thumbs:
020 83353032
DavidT
Post by DavidT » Sun Jan 20, 2008 12:37 pm
:lol: @ s4woody. I wonder who sells those ? ;)
My AIT's were high at Thorney & every other RR too :( SMIC's do not cope well there but are much better on the open road i.e. the gap is far less in performance terms. Like S4TAN said earlier, if you have good SMIC's on your car, you need to add bhp & torque to the RR peaks to get realistic on-road figures.
Users browsing this forum: No registered users and 58 guests
