Any ideas to maximise SMIC cooling on a RR with one fan?
Blue_Thunder
- Top Gear
I'm booked into a RR at Awesome GTI which only has one fan, but i've got RS4 intercoolers on my S4.
They've told me it's a fierce fan which creates up to 90mph flow, but i've no idea how much area this will cover, ie: whether it will have a wide enough area to cover both ic's. I suspect not.
Can anyone suggest anything which may help aid the cooling?
Would angling the fan across the front of the car slightly (as opposed to facing it straight on) be beneficial?
Would it be better to just concentrate all the cooling on one intercooler?
RE: Any ideas to maximise SMIC cooling on a RR with one fan?
if its a moveable fan then try not to have it too close..it mite flow more air through them that way..but im sure they no what there doing..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Ask them if they can put a wedge shaped 'splitter' in front of the fan - dead in the middle, so it diverts the flow to either side of the car.
Deus ex machina
BRETTCOLLINS
- 5th Gear
Seen this lots of times. waste of time mate. get them to watch the intake charge temp on the run. Did this on 5 different sets of rollers with my car had RS4 IC's. it will go through the roof... Can be done with VAG-com.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
Yep - both times my car has been on the rollers the IATs went thermonuclear. Don't expect a realistic reading from the dyno with SMICs - add another 15-20bhp on to the dyno results for the open road.
Deus ex machina
BRETTCOLLINS
- 5th Gear
Couple of years ago saw between 290bhp and 380bhp difference. LOL would run some logs of the intake temp on the open road before the day. then you can see if there fans are up to the job...
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Blue_Thunder
- Top Gear
Re: RE: Any ideas to maximise SMIC cooling on a RR with one
I had thought of nicking an old train snow plough!S4TAN wrote:Ask them if they can put a wedge shaped 'splitter' in front of the fan - dead in the middle, so it diverts the flow to either side of the car.
I was planning to do my own logging during the runs. Can high IAT's do any damage, or will the ECU just pull back the timing/fuelling to compensate?BRETTCOLLINS wrote:get them to watch the intake charge temp on the run.
BRETTCOLLINS
- 5th Gear
RE: Re: RE: Any ideas to maximise SMIC cooling on a RR with
On my car the ECU just backed everything off.
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Brett did the IAT's improve after you fitted Water injection?
BRETTCOLLINS
- 5th Gear
When I was running RS4 IC's yes the water injection was a must, made so much difference. Still helps with the FMIC now too
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Blue_Thunder
- Top Gear
Any ideas of what sort of IAT's you need to be running before the ECU will pull everything back?
BRETTCOLLINS
- 5th Gear
Sorry No idea......
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
My AIT's were high at Thorney & every other RR too
Users browsing this forum: No registered users and 40 guests
