could all S4 owners help me out with this list please
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
S4
Post by S4 » Fri Dec 28, 2007 8:32 pm
Hello guys.
I don't know this may be a good sticky if the replies are good as it will help many others. (project stop a leek)
Since owning my S4 I have been glued to the forum reading as much as I can about the cars.
The bottom line is these cars die quite quick with a boost leek, I have read so much, like peoples cars going bang with new turbos after just 2000 miles.
this scares the cra* out of most people and I can understand why, the cost can be bankrupting.
What I want is to try to make my pre-facelift as safe as I can from the dreaded monster boost leek. So I am trying to put a list together of the things that are needed and what hoses need to be changed for maybe silicone or whatever.
so far I have this
1) A leek tester
2) F hose (silicone?)
3) some say arp by pipe
can people please add to this and advise with links or part numbers what else is needed.
Thank you
Darren
S4TAN
RE: could all S4 owners help me out with this list please
Post by S4TAN » Fri Dec 28, 2007 9:31 pm
1) A leek tester
Some Welsh dude ... ?
Just joshin' .... get new DV's and a new TBB in addition to the silicon f-hose. Also check, and replace, various other hoses (FPR, boost/vacuum hoses to DV's etc...)
Deus ex machina
s4woody
Post by s4woody » Fri Dec 28, 2007 9:49 pm
not welsh..possibly a dyslexic angel..
arp by pipe
GARTH ROAD MOT CENTRE LTD
020 83353032
andybnwc
Post by andybnwc » Fri Dec 28, 2007 10:12 pm
i say do the lot , all hoses and get new 710 diverters and also check intercooler end caps when fitting the hoses for signs a leaking
Harper--D
Post by Harper--D » Fri Dec 28, 2007 11:17 pm
Just to add, s4 uses 710A's DV's, the DV's you want are the 710N's. Also, replace the 1 way valves and spider hose.
Dave.
White MK2 Golf.. Slightly modified :D
S4TAN
Post by S4TAN » Fri Dec 28, 2007 11:58 pm
Good call on the spider-hose HarperD ..... but good luck changing the "evil green" 1-way valve ... it's a reet bastard!
Deus ex machina
Harper--D
Post by Harper--D » Sat Dec 29, 2007 12:16 am
Also change little 1 way valve attached to f hose!
Dave.
andybnwc
Post by andybnwc » Sat Dec 29, 2007 12:34 am
is there a part number list anywhere for these 1 way valves and which ones are they? I constantly get boost problems could be one of these this time
S4
Re: RE: could all S4 owners help me out with this list pleas
Post by S4 » Sat Dec 29, 2007 1:31 am
s4woody wrote:from a old post 078133784AE or 035103245A its 1 of these i think..the 1st number is for a green valve..just cant remember what 1's what..
there is 3 of these green valves I think.
so added is spider hose.(there is a new model out?)
vac hoses
any more part numbers?
Darren
S4
RE: Re: RE: could all S4 owners help me out with this list p
Post by S4 » Sat Dec 29, 2007 6:34 pm
ok, is the valve the same in the F hose as the spider valve?
and what is FPR short for.
trying to make a list of safety part numbers..
S4TAN
Post by S4TAN » Sat Dec 29, 2007 9:10 pm
FPR = fuel pressure regulator
Deus ex machina
S4
Post by S4 » Sun Dec 30, 2007 5:50 pm
is that the pipes that go to the unit... or the actual unit
sounds expensive
Thanks guys
Darren
S4TAN
Post by S4TAN » Tue Jan 01, 2008 2:22 pm
Nah - just a rubber hose from the back of the intake manifold to the FPR unit - if you've still got the factory fitted hose then it's probably brittle and a bit shagged - easy job to replace for bugger-all cost.
Deus ex machina
S4
Post by S4 » Tue Jan 01, 2008 7:33 pm
S4TAN wrote:Nah - just a rubber hose from the back of the intake manifold to the FPR unit - if you've still got the factory fitted hose then it's probably brittle and a bit shagged - easy job to replace for bugger-all cost.
Thank you sir.
I have noticed that on other forums some people are using autobahn88 hoses (like samco) http://cgi.ebay.co.uk/Audi-S4-A6-2-7-Tw ... dZViewItem
and have said the quality is quite good, any views?
Darren
PaulyS4
Post by PaulyS4 » Fri Jan 04, 2008 10:39 am
Yea i had the whole set on My old s4 when i had my new turbo’s. They are defiantly better than standard, and are great value. When MRC's Doug pressure tested the car there was only 1 leak, which was on the original bi pipe all the autobahnn pipes were fine and have been ever since. Which is good as it is pushing 346bhp on RR. Also my friend has a set on his P1 Scooby and VRS Octavia, all is well with them and they are both remapped!!
B5 RS4 MTM 420 bhp
Misano RS4 with some MTM magic!!
Users browsing this forum: No registered users and 178 guests
