could all S4 owners help me out with this list please
Hello guys.
I don't know this may be a good sticky if the replies are good as it will help many others. (project stop a leek)
Since owning my S4 I have been glued to the forum reading as much as I can about the cars.
The bottom line is these cars die quite quick with a boost leek, I have read so much, like peoples cars going bang with new turbos after just 2000 miles.
this scares the cra* out of most people and I can understand why, the cost can be bankrupting.
What I want is to try to make my pre-facelift as safe as I can from the dreaded monster boost leek. So I am trying to put a list together of the things that are needed and what hoses need to be changed for maybe silicone or whatever.
so far I have this
1) A leek tester
2) F hose (silicone?)
3) some say arp by pipe
can people please add to this and advise with links or part numbers what else is needed.
Thank you
Darren
so far I have this
1) A leek tester
Thank you
Darren
RE: could all S4 owners help me out with this list please
Some Welsh dude ... ?1) A leek tester
Just joshin' .... get new DV's and a new TBB in addition to the silicon f-hose. Also check, and replace, various other hoses (FPR, boost/vacuum hoses to DV's etc...)
Deus ex machina
not welsh..possibly a dyslexic angel..
arp by pipe
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
i say do the lot , all hoses and get new 710 diverters and also check intercooler end caps when fitting the hoses for signs a leaking
Just to add, s4 uses 710A's DV's, the DV's you want are the 710N's. Also, replace the 1 way valves and spider hose.
Dave.
White MK2 Golf.. Slightly modified
Good call on the spider-hose HarperD ..... but good luck changing the "evil green" 1-way valve ... it's a reet bastard!
Deus ex machina
Also change little 1 way valve attached to f hose!
Dave.
is there a part number list anywhere for these 1 way valves and which ones are they? I constantly get boost problems could be one of these this time
Re: RE: could all S4 owners help me out with this list pleas
there is 3 of these green valves I think.s4woody wrote:from a old post 078133784AE or 035103245A its 1 of these i think..the 1st number is for a green valve..just cant remember what 1's what..
so added is spider hose.(there is a new model out?)
vac hoses
any more part numbers?
Darren
RE: Re: RE: could all S4 owners help me out with this list p
ok, is the valve the same in the F hose as the spider valve?
and what is FPR short for.
trying to make a list of safety part numbers..
FPR = fuel pressure regulator
Deus ex machina
Thank you sir.S4TAN wrote:Nah - just a rubber hose from the back of the intake manifold to the FPR unit - if you've still got the factory fitted hose then it's probably brittle and a bit shagged - easy job to replace for bugger-all cost.
I have noticed that on other forums some people are using autobahn88 hoses (like samco) http://cgi.ebay.co.uk/Audi-S4-A6-2-7-Tw ... dZViewItem
and have said the quality is quite good, any views?
Darren
Yea i had the whole set on My old s4 when i had my new turbo’s. They are defiantly better than standard, and are great value. When MRC's Doug pressure tested the car there was only 1 leak, which was on the original bi pipe all the autobahnn pipes were fine and have been ever since. Which is good as it is pushing 346bhp on RR. Also my friend has a set on his P1 Scooby and VRS Octavia, all is well with them and they are both remapped!!
B5 RS4 MTM 420 bhp
Misano RS4 with some MTM magic!!
Users browsing this forum: No registered users and 167 guests
