Talex speed camera and factory tinted windows
GardinerG
Post by GardinerG » Fri Aug 03, 2007 1:56 pm
I have a Talex (full version) speed camera detector that just doesn't want to work in my RS6. The problem seems to be that I have factory fitted tinted windows. The Talex will only pick up 1 satellite (if I am very lucky) when in the car), I've tried the window fixing kit etc.
Talex support told me that it uses a sirf 2 receiver, unlike my Tom Tom bluetooth GPS which uses sirf 3 and picks up 8 satellites.
Does anyone else have this problem? Anyone know a solution besides buying a different one, or sticking it on the roof!? :lol:
Grant
PetrolDave
RE: Talex speed camera and factory tinted windows
Post by PetrolDave » Fri Aug 03, 2007 2:56 pm
The SIRF 2 receiver is notoriously "deaf" and needs a strong GPS signal to work. The SIRF 3 is a much newer and better design which is much more sensitive.
Consign your Talex to the bin.
GardinerG
Post by GardinerG » Fri Aug 03, 2007 3:30 pm
I would but it's only 1 month old :roll:
Does anyone know which speed camera detectors have SIRF III receivers, I am struggling to find which do or don't!
reevesroadster
Post by reevesroadster » Tue Aug 21, 2007 10:56 pm
Grant,
I have a pogo alert which works well. 13 satellites typically from the front windscreen install.
As for GPS recievers, try Fortuna. Superb, and SIRF compliant.
Everyone is unique, just like you and me.
bobbler
Post by bobbler » Wed Aug 22, 2007 12:24 pm
Does the unit have an external aerial socket at all? I know some makes of them do so you could add an aerial mounted on the roof.
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
PetrolDave
Re: RE: Talex speed camera and factory tinted windows
Post by PetrolDave » Wed Aug 22, 2007 1:22 pm
reevesroadster wrote:I have a pogo alert which works well. 13 satellites typically from the front windscreen install.
Same here.
And my retrofitted RNS-E (GPS antenna underneath the dashboard) gets 8-9 satellites.
Return to “Electrical”
