Specialists in Bucks, Berks, Oxon
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
PaulR
Post by PaulR » Wed Jul 18, 2007 9:24 am
Was surprised yesterday when I discovered AMD has moved from Bicester to Thurrock, making it a real pain to continue to use them. Want to get car serviced, and also some suspension bushes changed (and hence realigned). Alternative specialists in the area appear to be MRC (Banbury) or Fontain (Slough). I have seen recommendations for MRC but nothing about Fontain from service perspective with these cars (B5 RS4). Are there any others within a sensible radius of High Wycombe that have good recommendations? I guess I could be drawn back to the dealership network ???
Appreciate input and views, and any other tipped specialists in the area.
Thanks, ... Paul.
DavidT
RE: Specialists in Bucks, Berks, Oxon
Post by DavidT » Wed Jul 18, 2007 9:31 am
APS: www.autops.co.uk are Ex AmD folks in that part of the world, with a good reputation from what I've seen.
MarkB
Post by MarkB » Wed Jul 18, 2007 9:43 am
Only heard good things about APS so worth a go I guess.
Esp. as you will need allignment also.
Mark
PaulR
Post by PaulR » Wed Jul 18, 2007 9:47 am
Very helpful sounding on the phone, and I am now awaiting a call back with some numbers. However, as far as suspension is concerned I need to get front lower and upper suspension arms rebushed and they are recommending replacement arms rather than replacing bushes because they say it's generally more economical, ... which has generated a very uneasy expecation in my wallet. Is this common?
Paul.
MarkB
Post by MarkB » Wed Jul 18, 2007 9:50 am
The ball joints also wears so replacing just the bush is considered uneconomical by most
Mark
Dippy
Post by Dippy » Wed Jul 18, 2007 12:56 pm
Are you in north or south Bucks? If south and getting to the M4 is easy enough, then you could also consider Dailynx in Swindon.
2001 Silver S4 Avant
PaulR
Post by PaulR » Fri Jul 20, 2007 5:27 pm
Am in South Bucks, near High Wycombe, so Swindon is quite easy either by M4 or Oxford and A420. And much the same distance as MRC or APS. Will give them a call on Monday if I can't get a confirm a slot with either of the others I've tried. Paul.
Return to “Audi S and RS Ownership”
