Was surprised yesterday when I discovered AMD has moved from Bicester to Thurrock, making it a real pain to continue to use them. Want to get car serviced, and also some suspension bushes changed (and hence realigned). Alternative specialists in the area appear to be MRC (Banbury) or Fontain (Slough). I have seen recommendations for MRC but nothing about Fontain from service perspective with these cars (B5 RS4). Are there any others within a sensible radius of High Wycombe that have good recommendations? I guess I could be drawn back to the dealership network ???
Appreciate input and views, and any other tipped specialists in the area.
Thanks, ... Paul.
Specialists in Bucks, Berks, Oxon
RE: Specialists in Bucks, Berks, Oxon
APS: www.autops.co.uk are Ex AmD folks in that part of the world, with a good reputation from what I've seen.
Only heard good things about APS so worth a go I guess.
Esp. as you will need allignment also.
Mark
Very helpful sounding on the phone, and I am now awaiting a call back with some numbers. However, as far as suspension is concerned I need to get front lower and upper suspension arms rebushed and they are recommending replacement arms rather than replacing bushes because they say it's generally more economical, ... which has generated a very uneasy expecation in my wallet. Is this common?
Paul.
Paul.
Are you in north or south Bucks? If south and getting to the M4 is easy enough, then you could also consider Dailynx in Swindon.
2001 Silver S4 Avant
