Dump Valves
Dump Valves
I have just had the management light come on and I have had somone check it for me and it is saying something along the lines of air leak. My question is I have the uprated valves and it looks like they have started to fail now is it worth going down the forge route or just buy new uprated ones again and has anyone got knowledge of the uprated valves part nos.
Mark
Mark
RE: Dump Valves
Do you really mean Dump Valves?? I used forge BPVs, and when I changed to the RS6 I bought a maintenance kit for £3 each to replace the seals etc before fitting them to it.
IMHO, worth the money as you never should need to replace them, just check them every 12,000 miles or so.
RE: Dump Valves
Do you mean uprated as in Bosch 710N's or something else? There's no such thing as a fit and forget BPV - the forge (all other pistons valves) need an annual service to replace the o-rings and re-grease, so my advice would be to fit a(nother?) set of 710Ns and have them checked at each service.
Buy hey, what do I know?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
RE: Dump Valves
Nige, re Forge BPVs... to be clear they should be tested every 12,000 miles and the maintenance kit used if needed, but £3 is alot cheaper than replacing the OEM BPVs. IMHO.
FYI, the kit includes piston, all seals and grease.
Surely they are tested everytime you drive the car??? They need to be removed and opened up - why not replace all the seals, pistons at the same time (BTW, Forge gave me a service kit FOC).tested every 12,000 miles
Worth bearing in mind that a set of Forge jobbies will set you back over £200, whereas the 710N's are less than £40 and TBH this is the first time I've heard of any problems with 710Ns - maybe the air leak error code is something more seious?
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
So did you install the Forge valves in the 6?I put the OEMs back in when I sold the car.
Yes, I'm having a bad (hair) day - see avatar
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
