Fitting spacers and wheel bolts. Advice needed plz
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
saf
Post by saf » Fri Apr 27, 2007 1:47 pm
Ive got a choiuce of going for an H&R spacer kit that comprises of the spacers 5mm each side, and also 5 bolts which are longer to give a tighter fit.
This is coming in at £30.95 per pair
Eibach pro spacers come in at £26.43 per pair. No bolts though.
Which is the better spacer.
And where can I buy bolts from if I go for the Eibach?
This is all going on an S4 with B6 s4 replicas 18 inch, 235 40 18 tyres.
Totally standard suspension. Im going for spacers because ill be putting the RS4 B7 / RS6 Caliper brake conversion.
Regards
S4TAN
RE: Fitting spacers and wheel bolts. Advice needed plz
Post by S4TAN » Fri Apr 27, 2007 2:07 pm
Saf - as you know i have the Eibach Pro-Spacers (5mm) all round - i didn't need longer bolts for them with my B6 reps ...
Don't know if they're better than the H&R spacers or not but the Eibach ones are very nice - well-machined, light, strong and properly balanced.
Deus ex machina
saf
Post by saf » Fri Apr 27, 2007 2:12 pm
I get the feeling that the Eibach ones are better.
So I guess that the bolts are definitely long enough to go in securely without a problem.
Im going to be popping over to MRC I hope on tuesday, so if youre around then pop down.
IF I dont need the bolts then all the beter.
The link you gave me sell both sets I outlined above. I was told by someone I would need longer bolts if I ran spacers on the car. I guess that 5mm is not that much.
Ill be having exactly the same reps as yours. Do you kno wwhere your reps are made mate?
MCB
Post by MCB » Fri Apr 27, 2007 2:14 pm
Julian's description sounds very similar to the H&R to me, £4 approx for five bolts sounds reasonable and they will be good quality so I would go with the all in H&R IMHO.
S4B5 Avant
gavsteryoung
Post by gavsteryoung » Mon Apr 30, 2007 5:09 pm
You will need longer bolts I am sure... with my 5mm Eibach spacers fitted behind my B6 Orginal Alloys I was only getting about 3 full turns on the orginal bolts and 7-8 with the old wheels....
in theory if you add a 5mm spacer you need a bolt 5mm longer than the stock ones.
09 Audi S3 - Sprint Blue
99 Audi S4 - Ming Blue - (Gone but not forgotten)
04 Vauxhall Tigra 1.8 Sport - Antiga Blue (The Mrs Car)
S4TAN
Post by S4TAN » Mon Apr 30, 2007 11:39 pm
Good point - i'd better check mine and see how many turns i'm getting - might have to get me some longer bolts!
Deus ex machina
Ads4
Post by Ads4 » Tue May 01, 2007 7:51 am
I ws told that I'd need longer bolts on anything over 3mm.
Adam.
MRC B5 S4 Avant.
S4TAN
Post by S4TAN » Tue May 01, 2007 9:38 am
Anyone know where i can get some longer wheel bolts of the correct size (13?) ... been looking on the web and just can't seem to find any ...
Deus ex machina
JonnyX
Post by JonnyX » Tue May 01, 2007 9:45 am
Daemon tweeks supplied mine when I bought 5mm eibach spacers from them. I think they are M14 not 13.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
S4TAN
Post by S4TAN » Tue May 01, 2007 9:55 am
Thanks Jonny - I was thinking they were 13s because the bolts i've got at the moment say 13 on the heads - but maybe that's nothing to do with the size(?) - can you remember the length of the bolts you got for 5mm spacers?
Deus ex machina
MCB
Post by MCB » Tue May 01, 2007 11:24 am
For bolts you could try SRB Power - Had this on file probably taken from the Forum at some point in the distant past...
H&R wheel bolts supplied from £1 each x 16 = £16.00 + VAT
They may also be able to supply locking wheel nuts
Tel: 01375 392777
https://www.srbpower.com/
S4B5 Avant
S4TAN
Post by S4TAN » Tue May 01, 2007 11:52 am
Thanks Paul ... will check it out.
Deus ex machina
S4TAN
Post by S4TAN » Tue May 01, 2007 12:06 pm
Just tried SRB - they no longer sell the wheel bolts separately!! :evil:
Deus ex machina
MCB
Post by MCB » Wed May 02, 2007 1:48 am
Oh wouldn't you know it, another old lead you could try PRI Racing Ltd http://www.priracing.co.uk/ Hope you have better luck this time...
S4B5 Avant
william64
Post by william64 » Wed May 02, 2007 7:07 am
You will need to ge the correct seat on the bolt
OE wheels are radius and aftermarket inc reps are generally 60 deg taper
P W Motorsport offers both spacers and bolts
Users browsing this forum: No registered users and 98 guests
