Fitting spacers and wheel bolts. Advice needed plz
Ive got a choiuce of going for an H&R spacer kit that comprises of the spacers 5mm each side, and also 5 bolts which are longer to give a tighter fit.
This is coming in at £30.95 per pair
Eibach pro spacers come in at £26.43 per pair. No bolts though.
Which is the better spacer.
And where can I buy bolts from if I go for the Eibach?
This is all going on an S4 with B6 s4 replicas 18 inch, 235 40 18 tyres.
Totally standard suspension. Im going for spacers because ill be putting the RS4 B7 / RS6 Caliper brake conversion.
Regards
Regards
RE: Fitting spacers and wheel bolts. Advice needed plz
Saf - as you know i have the Eibach Pro-Spacers (5mm) all round - i didn't need longer bolts for them with my B6 reps ...
Don't know if they're better than the H&R spacers or not but the Eibach ones are very nice - well-machined, light, strong and properly balanced.
Deus ex machina
I get the feeling that the Eibach ones are better.
So I guess that the bolts are definitely long enough to go in securely without a problem.
Im going to be popping over to MRC I hope on tuesday, so if youre around then pop down.
IF I dont need the bolts then all the beter.
The link you gave me sell both sets I outlined above. I was told by someone I would need longer bolts if I ran spacers on the car. I guess that 5mm is not that much.
Ill be having exactly the same reps as yours. Do you kno wwhere your reps are made mate?
Julian's description sounds very similar to the H&R to me, £4 approx for five bolts sounds reasonable and they will be good quality so I would go with the all in H&R IMHO.
S4B5 Avant
- gavsteryoung
You will need longer bolts I am sure... with my 5mm Eibach spacers fitted behind my B6 Orginal Alloys I was only getting about 3 full turns on the orginal bolts and 7-8 with the old wheels....
in theory if you add a 5mm spacer you need a bolt 5mm longer than the stock ones.
09 Audi S3 - Sprint Blue
99 Audi S4 - Ming Blue - (Gone but not forgotten)
04 Vauxhall Tigra 1.8 Sport - Antiga Blue (The Mrs Car)
Good point - i'd better check mine and see how many turns i'm getting - might have to get me some longer bolts!in theory if you add a 5mm spacer you need a bolt 5mm longer than the stock ones
Deus ex machina
I ws told that I'd need longer bolts on anything over 3mm.
Adam.
MRC B5 S4 Avant.
MRC B5 S4 Avant.
Anyone know where i can get some longer wheel bolts of the correct size (13?) ... been looking on the web and just can't seem to find any ...
Deus ex machina
Daemon tweeks supplied mine when I bought 5mm eibach spacers from them. I think they are M14 not 13.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Thanks Jonny - I was thinking they were 13s because the bolts i've got at the moment say 13 on the heads - but maybe that's nothing to do with the size(?) - can you remember the length of the bolts you got for 5mm spacers?
Deus ex machina
For bolts you could try SRB Power - Had this on file probably taken from the Forum at some point in the distant past...
H&R wheel bolts supplied from £1 each x 16 = £16.00 + VAT
They may also be able to supply locking wheel nuts
Tel: 01375 392777
https://www.srbpower.com/
Tel: 01375 392777
S4B5 Avant
Oh wouldn't you know it, another old lead you could try PRI Racing Ltd http://www.priracing.co.uk/ Hope you have better luck this time...
S4B5 Avant
