DRC Difference
tartan_rob
DRC Difference
What is the difference between RS6 and RS4 DRC and why do RS6's seem to have real problems with the system?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: DRC Difference
Theres no difference at all I believe!? Slightly different configuration of dampers etc but the principles are identical...
Present:...
Past:
Past:
- alex_123_fra
Why is the RS6 DRC so problematic? Keep seeing threads with several issues with it.
Does this mean the RS4 will go down the same route or is it somehow made more robust for this model?
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
Quite a number of new parts have failed when the system is repaired unfortunately... RS4 is a lighter car which should help reduce the forces on the shoxI think the early RS6's suffered from leaking dampers
Present:...
Past:
Past:
I believe ... and I have no other scientific basis for this other than this came from the master tech at my local dealership ... is that the B7 RS4 configuration has some additional isolation valves that can be closed to ensure the rest of the system doesn't get depressurised when changing out a shock. On the RS6 a lot of the problems stem from the depressurising and then repressurising of the DRC system. However, I don't see how these valves would help if there's a loss of pressure whilst driving ... if the pressure is gone then it's gone.
Again, only what I've been told ... could all be a just an old pile of
Rich.
Rich.
The Present ...
C7 RS6 Avant - Estoril Blue - everything bar B&O - Akrapovic only upgrade (... so far)
The Past ...
C6 RS6 Saloon - Phantom Black - lots of factory extras but no tuning.
C5 RS6 Saloon - Daytona with black Interior - Full Milltek with 100 cpsi cats - AMD Remap - Bilstein PSS9 Coilovers - MTM Bimoto's - Phaeton Brake Upgrade - RNS-E + Bluetooth + Multi-media player + Phatbox
911 (996) Turbo - X50 - Aerokit - PCCB
The Past ...
having had an rs6 with DRC problems and a major 3 month repair saga, with bad (understatement) dealer and Audi uk support) I have to say that I am waiting for my Rs4 to develop the same problem. I understand it is basically a very similar system and I think that there is/was? a steel and alloy washer electrolytic reaction problem that could lead to pressure problems in the system that led to the seals on the dampers failing. The subsequent leak from the dampers made it appear as if the damper was at fault so it was replaced. Not only was it not the primary problem, but as there were no isolation valves (these are fitted to the rs4 I think) new DRC valves were needed as the old ones cannot be repressurised and dealers for reasons of cost? tried to reuse the old DRC valves. I will certainly not keep my Rs4 outside 3 year warranty after my previous experience with the RS6. If any one has more information I would like to hear.
colin
colin
Users browsing this forum: No registered users and 341 guests
