DRC Difference
tartan_rob
DRC Difference
Post by tartan_rob » Thu Apr 19, 2007 7:39 am
What is the difference between RS6 and RS4 DRC and why do RS6's seem to have real problems with the system?
2017 Kawasaki Z1000
2014 RS6
2014 S1
SteveH
RE: DRC Difference
Post by SteveH » Thu Apr 19, 2007 8:24 am
Theres no difference at all I believe!? Slightly different configuration of dampers etc but the principles are identical...
Present:...
Past:
alex_123_fra
Post by alex_123_fra » Thu Apr 19, 2007 9:39 pm
Why is the RS6 DRC so problematic? Keep seeing threads with several issues with it.
Does this mean the RS4 will go down the same route or is it somehow made more robust for this model?
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
Daz
Post by Daz » Thu Apr 19, 2007 11:13 pm
I think the early RS6's suffered from leaking dampers. I hope they've resolved that issue with the RS4.
Cheers,
Daz :D
Audi RS4 Cabriolet with added Milltek - Gone :(
SteveH
Post by SteveH » Fri Apr 20, 2007 10:29 pm
Quite a number of new parts have failed when the system is repaired unfortunately... RS4 is a lighter car which should help reduce the forces on the shox
Present:...
Past:
Rich_C
Post by Rich_C » Sat Apr 21, 2007 8:58 am
I believe ... and I have no other scientific basis for this other than this came from the master tech at my local dealership ... is that the B7 RS4 configuration has some additional isolation valves that can be closed to ensure the rest of the system doesn't get depressurised when changing out a shock. On the RS6 a lot of the problems stem from the depressurising and then repressurising of the DRC system. However, I don't see how these valves would help if there's a loss of pressure whilst driving ... if the pressure is gone then it's gone.
Again, only what I've been told ... could all be a just an old pile of :dung:
Rich.
The Present ...
C7 RS6 Avant - Estoril Blue - everything bar B&O - Akrapovic only upgrade (... so far)
The Past ...
C6 RS6 Saloon - Phantom Black - lots of factory extras but no tuning.
C5 RS6 Saloon - Daytona with black Interior - Full Milltek with 100 cpsi cats - AMD Remap - Bilstein PSS9 Coilovers - MTM Bimoto's - Phaeton Brake Upgrade - RNS-E + Bluetooth + Multi-media player + Phatbox
911 (996) Turbo - X50 - Aerokit - PCCB
minou
Post by minou » Sun Apr 22, 2007 8:25 pm
having had an rs6 with DRC problems and a major 3 month repair saga, with bad (understatement) dealer and Audi uk support) I have to say that I am waiting for my Rs4 to develop the same problem. I understand it is basically a very similar system and I think that there is/was? a steel and alloy washer electrolytic reaction problem that could lead to pressure problems in the system that led to the seals on the dampers failing. The subsequent leak from the dampers made it appear as if the damper was at fault so it was replaced. Not only was it not the primary problem, but as there were no isolation valves (these are fitted to the rs4 I think) new DRC valves were needed as the old ones cannot be repressurised and dealers for reasons of cost? tried to reuse the old DRC valves. I will certainly not keep my Rs4 outside 3 year warranty after my previous experience with the RS6. If any one has more information I would like to hear.
colin
Users browsing this forum: No registered users and 274 guests
