B6 S4 MaF readings...
tartan_rob
I did some runs the other day, max reading 268G/s @ 6800rpm....
Anyone else done any to compare?
I have no engine mods apart from full Miltek with no cats, std air filter (for some daft reason...)..run was done in 2nd and 3rd gears
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Uwe@Ross-Tech
- 1st Gear
RE: B6 S4 MaF readings...
268 g/s divided by 0.8 = 335 hp. Sounds just about right for an S4.
What would have been interesting is if you had done runs before and after the exhaust mods. My guess is it doesn't do much except make noise..
-Uwe-
-Uwe-
tartan_rob
Uwe - if that calculation is right then I would definately agree. The noise though is simply glorious....
On another note I thought the 0.8 calculation was only for the 2.7t engine?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Uwe@Ross-Tech
- 1st Gear
Nope, basically it takes a known amount of air and fuel to produce a certain number of horsepower. Any variation would be due to differences in the thermal efficiency of the engines, but modern engines should all be very close in that regard. So the 0.8 g/s per horsepower is a valid rule of thumb for all modern gasoline (petrol) engines.
Of course diesels are a completely different animal.
-Uwe-
-Uwe-
Re: RE: B6 S4 MaF readings...
Interesting this calculation makes my car 415bhp (332 / 0.8 )Tartan_Rob wrote: On another note I thought the 0.8 calculation was only for the 2.7t engine?
tartan_rob
RE: Re: RE: B6 S4 MaF readings...
Depends on what mods you have and of course it is not exact but a ball park figure. a std B5 MAF top out around 332 gal/s, to go higher you need to look at an RS4 MAF. You may be runing higher than that. A Fats run will give you a better idea of what power you are running.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Mine did make about 286 g/s(i think) (s4 - 4.2 v8 B6) - Corey can confirm as he had the laptop on his lap
but lately with that map i've had issues (*see my other tread) LMAO
tartan_rob
Re: RE: Re: RE: B6 S4 MaF readings...
It has the eo sotware on it but thats about it - might be wrong , i'll check with corey and post accordingly .Tartan_Rob wrote:286 is high for a std V8 B6.
RE: Re: RE: Re: RE: B6 S4 MaF readings...
I was wrong, it was 283.1
And i Ment to type Revo software not the eo software
tartan_rob
283.1, Is that with Revo?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
Correct, that's with the Revo software runningTartan_Rob wrote:283.1, Is that with Revo?
RE: Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
Not Normal
Are you a member of Coreys family?
Joking apart.
Did some the other day stock apart from a Milltek and light 19" wheels 272 on the maf, original maf not changed from new.
Joking apart.
Re: RE: Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
No, no relation to Coreywilliam64 wrote:Not Normal
Don't gt the joke here ???
What off set are your wheels and are you runnning spacers ??william64 wrote:Not Normal
- Corey
- 2nd Gear
Care to explain that comment further please.william64 wrote:Not Normal
Corey
Users browsing this forum: No registered users and 52 guests
