B6 S4 MaF readings...
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
tartan_rob
Post by tartan_rob » Wed Feb 07, 2007 6:22 pm
I did some runs the other day, max reading 268G/s @ 6800rpm....
Anyone else done any to compare?
I have no engine mods apart from full Miltek with no cats, std air filter (for some daft reason...)..run was done in 2nd and 3rd gears
2017 Kawasaki Z1000
2014 RS6
2014 S1
Uwe@Ross-Tech
RE: B6 S4 MaF readings...
Post by Uwe@Ross-Tech » Wed Feb 07, 2007 9:18 pm
268 g/s divided by 0.8 = 335 hp. Sounds just about right for an S4.
What would have been interesting is if you had done runs before and after the exhaust mods. My guess is it doesn't do much except make noise..;-)
-Uwe-
tartan_rob
Post by tartan_rob » Thu Feb 08, 2007 5:08 pm
Uwe - if that calculation is right then I would definately agree. The noise though is simply glorious....
On another note I thought the 0.8 calculation was only for the 2.7t engine?
2017 Kawasaki Z1000
2014 RS6
2014 S1
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Thu Feb 08, 2007 6:50 pm
Nope, basically it takes a known amount of air and fuel to produce a certain number of horsepower. Any variation would be due to differences in the thermal efficiency of the engines, but modern engines should all be very close in that regard. So the 0.8 g/s per horsepower is a valid rule of thumb for all modern gasoline (petrol) engines.
Of course diesels are a completely different animal.
-Uwe-
si_hill
Re: RE: B6 S4 MaF readings...
Post by si_hill » Sun Feb 11, 2007 6:51 pm
Tartan_Rob wrote: On another note I thought the 0.8 calculation was only for the 2.7t engine?
Interesting this calculation makes my car 415bhp (332 / 0.8 )
tartan_rob
RE: Re: RE: B6 S4 MaF readings...
Post by tartan_rob » Sun Feb 11, 2007 11:18 pm
Depends on what mods you have and of course it is not exact but a ball park figure. a std B5 MAF top out around 332 gal/s, to go higher you need to look at an RS4 MAF. You may be runing higher than that. A Fats run will give you a better idea of what power you are running.
2017 Kawasaki Z1000
2014 RS6
2014 S1
NotNormal
Post by NotNormal » Thu Mar 08, 2007 11:44 pm
Mine did make about 286 g/s(i think) (s4 - 4.2 v8 B6) - Corey can confirm as he had the laptop on his lap ;)
but lately with that map i've had issues (*see my other tread) LMAO
tartan_rob
Post by tartan_rob » Fri Mar 09, 2007 1:21 pm
286 is high for a std V8 B6.
2017 Kawasaki Z1000
2014 RS6
2014 S1
NotNormal
Re: RE: Re: RE: B6 S4 MaF readings...
Post by NotNormal » Fri Mar 09, 2007 4:03 pm
Tartan_Rob wrote:286 is high for a std V8 B6.
It has the eo sotware on it but thats about it - might be wrong , i'll check with corey and post accordingly .
NotNormal
RE: Re: RE: Re: RE: B6 S4 MaF readings...
Post by NotNormal » Fri Mar 09, 2007 6:28 pm
I was wrong, it was 283.1 ;)
And i Ment to type Revo software not the eo software :roll: :)
tartan_rob
Post by tartan_rob » Tue Mar 13, 2007 11:44 am
283.1, Is that with Revo?
2017 Kawasaki Z1000
2014 RS6
2014 S1
NotNormal
Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
Post by NotNormal » Tue Mar 13, 2007 5:18 pm
Tartan_Rob wrote:283.1, Is that with Revo?
Correct, that's with the Revo software running
william64
RE: Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
Post by william64 » Mon Apr 09, 2007 11:37 pm
Not Normal
Are you a member of Coreys family?
Joking apart.
Did some the other day stock apart from a Milltek and light 19" wheels 272 on the maf, original maf not changed from new.
NotNormal
Re: RE: Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
Post by NotNormal » Tue Apr 10, 2007 2:23 pm
william64 wrote:Not Normal
No, no relation to Corey :?
Don't gt the joke here ??? :?:
What off set are your wheels and are you runnning spacers ??
Corey
Post by Corey » Thu Apr 12, 2007 10:44 am
Care to explain that comment further please.
Corey
Return to “DTC / VCDS”
