trying to find some info - Gearboxes
kylewc
Post by kylewc » Mon Dec 18, 2006 2:56 pm
hi all,
have searched all forums but couldnt find anything on any. i am trying to find out the following for the B5 S4:
-gear ratios 1-6
-final drive (and any other gear ratios that are appropriate)
-drag coeffs (have found avant=0.31 and saloon =0.33 is this right?)
-frontal area i can measure it but could do with 'official' value
any help is much appreciated.
Kyle
docurley
RE: trying to find some info
Post by docurley » Mon Dec 18, 2006 3:00 pm
kylewc
Post by kylewc » Mon Dec 18, 2006 3:14 pm
thats the kind of thing i'm after - thanks
don't suppose you could send me that excel file that was used to make that, may save me a while!
my username @ blueyonder . co . uk
docurley
Post by docurley » Tue Dec 19, 2006 12:07 am
Sorry mate got it from another thread like that.
saf
Post by saf » Tue Dec 19, 2006 10:52 am
Looking at that, very interesting.
Do you know where I can find the gear ratios for the RS4 B5 or even the RS6 to compare?
kylewc
Post by kylewc » Tue Dec 19, 2006 11:25 am
still looking for the actual ratios. those numbers are a bit out, so if you come across them anywhere for the s4 pls let me know. have hunted high and low already with no luck (thats for ratios of any kind (S4/RS4 etc... ))...
QuantumJohn
Post by QuantumJohn » Mon Jan 15, 2007 4:42 pm
Rather than start a new thread thought I would drag up an oldie.
I have also searched for these ratios but can't find any. Did you find them Kyle?
Is any one else able to help. I'd like the ratios for the S4 and RS4 gearbox to see where they differ.
Many thanks,
John
MCB
Post by MCB » Mon Jan 15, 2007 5:38 pm
John, check this out:
http://www.elektro.com/~audi/01E/
S4B5 Avant
ChipHazzard
Post by ChipHazzard » Mon Jan 15, 2007 7:27 pm
John
I think I saw the ratios in Elsawin, I'll try and have a look a bit later on
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
ChipHazzard
Post by ChipHazzard » Mon Jan 15, 2007 11:41 pm
John
This should help
Gearbox identification
Code letters, assignment of mechanical units, transmission ratios, capacities
Manual gearbox
Code letters DSY EDU
Manufactured from 05.97 07.99
to 12.98 10.00
Assignment Model Audi A4 1995 > Audi A4 1995 >
Engine 2.7l - 195 kW - S4 2.7 l - 184 kW - S4
Transmission ratio Final drive 37 : 9 = 4.111 37 : 9 = 4.111
Z2 :Z1=i 1st gear 28 : 8 = 3.500 28 : 8 = 3.500
2nd gear 34 : 18 = 1.889 34 : 18 = 1.889
3rd gear 32 : 26 = 1.231 32 : 26 = 1.231
4th gear 29 : 30 = 0.967 29 : 30 = 0.967
5th gear 29 : 36 = 0.806 29 : 36 = 0.806
6th gear 26 : 38 = 0.684 26 : 38 = 0.684
Reverse gear 38 : 11 = 3.455 38 : 11 = 3.455
Speedometer Electronic
Capacity 3.4 litres 1)2) 2.5 litres 1)
Specification Gear oil G 052 911 A SAE 75 W 90 (synthetic)
Clutch mechanism Hydraulic
Clutch plate ø 240 mm 3)
Drive shaft flange ø 108 mm 108 mm
itot in top gear 2.813 2.813
Rear final drive assignment
Code letters DQA DQA
1) Reduced oil quantity
2) Oil quantity includes 0.3 l for gear oil cooler and oil pipe. Oil cooler and oil pipe must be completely drained on replacing gearbox.
3) With dual-mass flywheel
4) For triple roller joint/drive shaft with centring diameter 130 mm
Manual gearbox 6-speed 01E Four-wheel drive
Code letters FDP FRQ
Manufactured from 11.00 04.01
to 04.01 09.01
Engine 2.7l - 280 kW - RS4 2.7l - 195 kW - S4
3rd gear 33 : 25 = 1.320 32 : 26 = 1.231
4th gear 30 : 29 = 1.034 29 : 30 = 0.967
Capacity 3.4 litres 1)2) 3.4 litres 1)2)
Code letters FTG
Manufactured From 04.01
To 09.01
Engine 2.7 l - 184 kW - S4
Code letters FTG
Capacity 2.5 litres 1)
Itot in top gear 2.813
Code letters DQA
Code letters FTU FZV 5) FZW 5)
Manufactured from 04.01 01.02 01.02
to 09.01
Assignment Model Audi A4 1995 > Audi A4 1995 > Audi A4 1995 >
Engine 2.7 l - 280 kW - RS4 2.7 l - 195 kW - S4 2.7 l - 280 kW - RS4
Transmission ratio Final drive 37 : 9 = 4.111 37 : 9 = 4.111 37 : 9 = 4.111
Z2 :Z1=i 1st gear 28 : 8 = 3.500 28 : 8 = 3.500 28 : 8 = 3.500
2nd gear 34 : 18 = 1.889 34 : 18 = 1.889 34 : 18 = 1.889
3rd gear 33 : 25 = 1.320 32 : 26 = 1.231 33 : 25 = 1.320
4th gear 30 : 29 = 1.034 29 : 30 = 0.967 30 : 29 = 1.034
5th gear 29 : 36 = 0.806 29 : 36 = 0.806 29 : 36 = 0.806
6th gear 26 : 38 = 0.684 26 : 38 = 0.684 26 : 38 = 0.684
Reverse gear 38 : 11 = 3.455 38 : 11 = 3.455 38 : 11 = 3.455
5) Service gearbox for S4 and RS4; modified synchro-rings for 1st and 2nd gear (with carbon coating) and modified locking collar/synchro-hub for 1st/2nd gear
Capacity 3.4 litres 1)2) 3.4 litres 1)2) 3.4 litres 1)2)
Drive shaft flange ø 108 mm 108 mm 108 mm
itot in top gear 2.813 2.813 2.813
Code letters DQA DQA DQA
Code letters FZY 5)
Manufactured from 01.02
to
Code letters FZY 5)
Code letters DQA
FL Noggy S4 Avant
QuantumJohn
Post by QuantumJohn » Tue Jan 16, 2007 4:12 pm
Mike,
That's brilliant, thanks for all of that.
To summarise then:
S4 with gearbox code DSY has the same gear ratios as the early RS4 box that had the potential 1st and 2nd gear synchro fault coded FDP.
The later RS4 gearboxes (code FTU) and those replaced under warranty (code FZW) have different ratios for 4th and 5th gears.
They all have the same final drive.
So, finally what is the difference between the S4 and RS4 gearbox, gear ratios aside for the later versions?
Thanks,
John
QuantumJohn
Post by QuantumJohn » Tue Jan 16, 2007 11:16 pm
After doing more research have also found that the Torsen bias ratios are 4:1 for RS4 and 2:1 for S4. Hence the RS4 can deliver 80% to one axle, S4 66%.
I really need to know what other advantages there are to fitting the RS4 box over the S4 one.
And soon!
Thanks for any help,
John
QuantumJohn
RS4 gearbox vs S4 one
Post by QuantumJohn » Wed Jan 17, 2007 9:52 am
Other than the one advantage I have posted above (Torsen bias ratio) is there any other reason to fit an RS4 box?
It seems a few people do it but other than the above I see little difference.
Thanks,
John
DavidT
Re: RS4 gearbox vs S4 one
Post by DavidT » Wed Jan 17, 2007 10:44 am
QuantumJohn wrote:Other than the one advantage I have posted above (Torsen bias ratio) is there any other reason to fit an RS4 box?
Thanks,
John
I've read in various places that the later RS4 gearboxes are stronger than earlier ones and all S4 versions. Not sure if thats true.
The lower ratios and better TorSen bias are both good reasons IMO.
Let us know if you find anything else John :)
dodgydave
Post by dodgydave » Wed Jan 17, 2007 1:35 pm
QuantumJohn wrote:After doing more research have also found that the Torsen bias ratios are 4:1 for RS4 and 2:1 for S4. Hence the RS4 can deliver 80% to one axle, S4 66%.
And soon!
John
Well,
You see I thought the same. But then I checked with Stasis because they even mention the 2:1 S4 and 4:1 RS4 difference on their webpage. They admit that the text is misleading as they wanted to write you can get closer to the RS4 B7 feel.
Anyway, they said in all the RS4 boxes they have done they have yet to find a 4:1 ratio torsen.
They modified my RS4 torsion from 2:1 to 4:1. And also if you check in ETKA you will find that the S4 torsen has the same P/N as the RS4 torsen. 01e 409 751 f
So, the 4:1 split in the RS4 seems to be a wide spread myth!
Users browsing this forum: No registered users and 70 guests
