Exhaust Gas Temp Sensor
Had someone plug their vag com in to my 98 s4 and it came up with this:-
18010 power supply to term 30 voltage 2 low p1602-35-10 intermittent exhaust gas temp sensor.
Does this mean my EGT's are fooked?
Wide Body S4
- 1st Gear
RE: Exhaust Gas Temp Sensor
None of the numbers you've posted have anything to do with the EGT sensor.
Are you sure you're not stringing two fault codes together and skipping the numbers from the second fault?
-Uwe-
-Uwe-
No that is exactly as it was on the screen? Now i am confused??? I know that the EGT did come up as well. How urgent is it that i change them?
Wide Body S4
- 1st Gear
Using VAG-COM?No that is exactly as it was on the screen
- If so, is there chance you're using some dodgy version gotten someplace other than our website?
- - If so, you might want to download and install a fresh copy from our download page.
- - - If it still shows that, make a screen-shot and e-mail it to me please.
-Uwe-
The car will struggle to enrich on high boost.
It is not difficult to fix and many many cars run on broken egts.
Some cars go to limp some don't.
egt failure can also be as a result of lean running and manifold failure.
Vag is essential
Log block 111
Log block 2
log block 20
Log block 32 aslo
and get codes.
Egt code will usually mean its broken not a big issue dont worry.
Simply find out the bank 1 or 2 order the part bank 2, is a bit more difficult.
Hope this helps
G
Vag is essential
Log block 111
Log block 2
log block 20
Log block 32 aslo
and get codes.
Hope this helps
G
Uwe - i am having it downloaded again next week so i will take a screen shot and post it here. Thanks
flashyg - this is a great help thanks. When i get it downloaded again next week i will know what to look for. Best place to buy them from?
Wide Body S4
- ChipHazzard
Ok thread jacking time
I have just run a scan and got back this code
Address 01: Engine
Part No: 8D0 907 551 D
Component: 2.7l V6/5VT 01 0002
Coding: 05711
Shop #: WSC 06325
1 Fault Found:
17867 - Exhaust Gas Temp Sensor 2 (G236): Implausible Signal
P1459 - 35-10 - - - Intermittent
Readiness: 0000 0000
Is it time to reach for the wallet and dent the plastic or am I safe for the moment. I have cleared the code but not had a chance to nip out for a spin and see if the fault comes back
Thanks in advance
Mike
Address 01: Engine
Coding: 05711
Shop #: WSC 06325
1 Fault Found:
Thanks in advance
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
Is G236 the passenger's side sensor?
- ChipHazzard
IIRC yes G236 is the passengers side it's in the self study guide in the downloads section, both sensor's are the same
HTH
Mike
HTH
Mike
FL Noggy S4 Avant
What a brilliant bit of reading that is!
Users browsing this forum: No registered users and 26 guests
