Exhaust Gas Temp Sensor
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
h8cak
Post by h8cak » Tue Nov 21, 2006 6:51 pm
Had someone plug their vag com in to my 98 s4 and it came up with this:-
18010 power supply to term 30 voltage 2 low p1602-35-10 intermittent exhaust gas temp sensor.
Does this mean my EGT's are fooked?
Wide Body S4
Uwe@Ross-Tech
RE: Exhaust Gas Temp Sensor
Post by Uwe@Ross-Tech » Tue Nov 21, 2006 10:53 pm
None of the numbers you've posted have anything to do with the EGT sensor.
Are you sure you're not stringing two fault codes together and skipping the numbers from the second fault?
-Uwe-
h8cak
Post by h8cak » Tue Nov 21, 2006 11:28 pm
No that is exactly as it was on the screen? Now i am confused??? I know that the EGT did come up as well. How urgent is it that i change them?
Wide Body S4
Uwe@Ross-Tech
Post by Uwe@Ross-Tech » Thu Nov 23, 2006 12:37 am
Using VAG-COM?
- If so, is there chance you're using some dodgy version gotten someplace other than our website?
- - If so, you might want to download and install a fresh copy from our download page.
- - - If it still shows that, make a screen-shot and e-mail it to me please.
-Uwe-
flashyg
Post by flashyg » Thu Nov 23, 2006 10:30 pm
The car will struggle to enrich on high boost.
It is not difficult to fix and many many cars run on broken egts.
Some cars go to limp some don't.
egt failure can also be as a result of lean running and manifold failure.
Vag is essential
Log block 111
Log block 2
log block 20
Log block 32 aslo
and get codes.
Egt code will usually mean its broken not a big issue dont worry.
Simply find out the bank 1 or 2 order the part bank 2, is a bit more difficult.
Hope this helps
G
h8cak
Post by h8cak » Thu Nov 23, 2006 10:34 pm
Uwe - i am having it downloaded again next week so i will take a screen shot and post it here. Thanks
flashyg - this is a great help thanks. When i get it downloaded again next week i will know what to look for. Best place to buy them from?
Wide Body S4
ChipHazzard
Post by ChipHazzard » Thu Nov 23, 2006 11:50 pm
Ok thread jacking time
I have just run a scan and got back this code
Address 01: Engine
Part No: 8D0 907 551 D
Component: 2.7l V6/5VT 01 0002
Coding: 05711
Shop #: WSC 06325
1 Fault Found:
17867 - Exhaust Gas Temp Sensor 2 (G236): Implausible Signal
P1459 - 35-10 - - - Intermittent
Readiness: 0000 0000
Is it time to reach for the wallet and dent the plastic or am I safe for the moment. I have cleared the code but not had a chance to nip out for a spin and see if the fault comes back
Thanks in advance
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
yorkie
Post by yorkie » Mon Apr 02, 2007 8:56 pm
Is G236 the passenger's side sensor?
ChipHazzard
Post by ChipHazzard » Mon Apr 02, 2007 9:02 pm
IIRC yes G236 is the passengers side it's in the self study guide in the downloads section, both sensor's are the same
HTH
Mike
FL Noggy S4 Avant
yorkie
Post by yorkie » Tue Apr 03, 2007 7:23 pm
What a brilliant bit of reading that is!
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 20 guests
