Can you change the faceplates on Navigation plus?
keithly33
Post by keithly33 » Sat Oct 21, 2006 10:48 pm
I have a navigation plus for an Audi A4 B5 which is not working. If I buy one for an A6 can I swap the faceplates without causing a problem ?
Thanks.
Keith.
peterb
RE: Can you change the faceplates on Navigation plus?
Post by peterb » Mon Oct 23, 2006 10:20 am
Yes, the faceplates can be changed fairly easily.
Suzuki Carry 660
keithly33
Post by keithly33 » Mon Oct 23, 2006 7:23 pm
Thanks. :D
Dippy
Post by Dippy » Tue Oct 24, 2006 2:20 pm
Hmm, my memory of changing my faceplate over does not quite match Peter's use of the words "fairly easily". Not as difficult as removing the aircon control unit but not far off! The trouble is that to pull off the fascia you need to depress 4 lugs simultaneously, and also the hole is exactly the same size as the unit, so there is virtually no room for manoeuver!
2001 Silver S4 Avant
Return to “Electrical”
