I have a navigation plus for an Audi A4 B5 which is not working. If I buy one for an A6 can I swap the faceplates without causing a problem ?
Thanks.
Keith.
Can you change the faceplates on Navigation plus?
RE: Can you change the faceplates on Navigation plus?
Yes, the faceplates can be changed fairly easily.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
Suzuki Carry 660
Hmm, my memory of changing my faceplate over does not quite match Peter's use of the words "fairly easily". Not as difficult as removing the aircon control unit but not far off! The trouble is that to pull off the fascia you need to depress 4 lugs simultaneously, and also the hole is exactly the same size as the unit, so there is virtually no room for manoeuver!
2001 Silver S4 Avant
Users browsing this forum: No registered users and 111 guests
