Interior Door Handles - B5 Cars - help needed!
I have an issue with the drivers interior door handle. It clicked when I opened the door and is now a little wobbly.
I read on a forum somewhere that it is broken and a part needs to be replaced.
Does anyone know what it is please ?
I'm off down to the dealer at lunchtime today and would like to get one.
Thanks in advance
David
Thanks in advance
David
diagram
hi Dave,
not sure the problem sorry but maybe the diagram can shed some light? or if someone knows the part they can tell you the number on this.
hth
Oli
hth
Oli
- Attachments
- diagram
- doorhandle.gif (13.49 KiB) Viewed 1165 times
S4 B5 - MRC
RE: diagram
David, the best way might be to take the door panel off and have alook whats broken or come away? It only takes few minutes to remove the whole door panel.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
RE: diagram
Thanks guys, that diagram looks complicated
I will remove the panel and take the broken bit to the local dealer.
RE: diagram
i recon its got to be something either the rod (28) or the thing that holds the actual lever in place would that be (29), like you say take it apart and see whats broke
S4 B5 - MRC
Could be that the door 'trigger' retaining spring has popped off. Mine was loose when I bought the car as the spring was missing. I guess if it has popped off you may be able to find it inside the door and put it back on.
I bought a whole replacement door trigger assembly (it comes with the tweeter speaker holder as well) from VAG Parts and it was only around £20 from memory.
The door card is simple to remove, I've never owned a car where it's been so easy. One screw at either end at the top and one behind the pull handle. Then it just lifts off, taking care with all the electrical connections of course.
Jarv
Jarv
Mike
Q7
Q7
- quattrosteph
Handle...
I have the same problem with mine....Sometimes it does, sometimes not!! I think there is a spring inside and it must be " Kapput"!!! Will fix it when i have some spare time
Porsche 996 Turbo S Atlas Grey.
RS4 B7 Avant Sprint Blue. Sold.
RS4 B5 Avus Silver with MRC magic . Sold (Best car ever )
S4 B6 Avant Nogaro blue. Sold
A6 Avant Silver . 2.5 TDI .Sold
RE: Handle...
David, Did you ever get to the bottom of this?
I heard a twang from my drivers door handle today... it's now a little looser than the passenger one
Mark
Re: RE: Handle...
Nope, keep meaning to, but have not got around to it yet.MarkB wrote:David, Did you ever get to the bottom of this?
Sounds like yours has done the same thing. I'll race you
RE: Re: RE: Handle...
Well, I finally got around to doing this little job, lazy arse that I am
Dead easy really, you just remove the interior handle & door panel, then remove & replace the interior handle.
It is the handle spring that breaks, but the fixing wears also, I got an ebay RS4 handle new (thanks MarkB
) and swapped the bits over as you can get it all apart no problem
Good work David. You be careful, next you'll be saying you washed the car!
Mark
