Interior Door Handles - B5 Cars - help needed!
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
DavidT
Post by DavidT » Thu Sep 28, 2006 11:50 am
I have an issue with the drivers interior door handle. It clicked when I opened the door and is now a little wobbly.
I read on a forum somewhere that it is broken and a part needs to be replaced.
Does anyone know what it is please ?
I'm off down to the dealer at lunchtime today and would like to get one.
Thanks in advance
David
DavidT
RE: Interior Door Handles - B5 Cars - help needed!
Post by DavidT » Thu Sep 28, 2006 1:33 pm
No one ? :cry:
oliew
diagram
Post by oliew » Thu Sep 28, 2006 4:26 pm
hi Dave,
not sure the problem sorry but maybe the diagram can shed some light? or if someone knows the part they can tell you the number on this.
hth
Oli
diagram
S4 B5 - MRC
Nige_RS4
RE: diagram
Post by Nige_RS4 » Thu Sep 28, 2006 4:32 pm
David, the best way might be to take the door panel off and have alook whats broken or come away? It only takes few minutes to remove the whole door panel.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
DavidT
RE: diagram
Post by DavidT » Thu Sep 28, 2006 4:35 pm
Thanks guys, that diagram looks complicated :(
I will remove the panel and take the broken bit to the local dealer.
:thumbs:
oliew
RE: diagram
Post by oliew » Thu Sep 28, 2006 4:38 pm
i recon its got to be something either the rod (28) or the thing that holds the actual lever in place would that be (29), like you say take it apart and see whats broke :)
S4 B5 - MRC
Jarv
Post by Jarv » Thu Sep 28, 2006 10:10 pm
Could be that the door 'trigger' retaining spring has popped off. Mine was loose when I bought the car as the spring was missing. I guess if it has popped off you may be able to find it inside the door and put it back on.
I bought a whole replacement door trigger assembly (it comes with the tweeter speaker holder as well) from VAG Parts and it was only around £20 from memory.
The door card is simple to remove, I've never owned a car where it's been so easy. One screw at either end at the top and one behind the pull handle. Then it just lifts off, taking care with all the electrical connections of course.
Jarv
Mike
Q7
quattrosteph
Handle...
Post by quattrosteph » Sat Sep 30, 2006 9:11 pm
I have the same problem with mine....Sometimes it does, sometimes not!! I think there is a spring inside and it must be " Kapput"!!! Will fix it when i have some spare time :)
Porsche 996 Turbo S Atlas Grey.
RS4 B7 Avant Sprint Blue. Sold.
RS4 B5 Avus Silver with MRC magic . Sold (Best car ever )
S4 B6 Avant Nogaro blue. Sold
A6 Avant Silver . 2.5 TDI .Sold
MarkB
RE: Handle...
Post by MarkB » Wed Dec 06, 2006 3:13 pm
David, Did you ever get to the bottom of this?
I heard a twang from my drivers door handle today... it's now a little looser than the passenger one :(
Mark
DavidT
Re: RE: Handle...
Post by DavidT » Wed Dec 06, 2006 3:35 pm
MarkB wrote:David, Did you ever get to the bottom of this?
Nope, keep meaning to, but have not got around to it yet.
Sounds like yours has done the same thing. I'll race you :)
MarkB
RE: Re: RE: Handle...
Post by MarkB » Wed Dec 06, 2006 3:55 pm
The speed I work, I think you'll win. ;)
Mark
MarkB
Post by MarkB » Fri Jun 15, 2007 10:11 am
Anyone got the part number for the bit needed to fix the drivers door?
Mark
DavidT
Post by DavidT » Thu Apr 03, 2008 10:08 am
Well, I finally got around to doing this little job, lazy arse that I am :oops:
Dead easy really, you just remove the interior handle & door panel, then remove & replace the interior handle.
It is the handle spring that breaks, but the fixing wears also, I got an ebay RS4 handle new (thanks MarkB :) ) and swapped the bits over as you can get it all apart no problem :)
MarkB
Post by MarkB » Thu Apr 03, 2008 10:20 am
Good work David. You be careful, next you'll be saying you washed the car! :D
Mark
Return to “Audi S and RS Ownership”
