central locking problem after a monsoon in york
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
mikecmr
Post by mikecmr » Thu Sep 14, 2006 9:01 pm
after it totally chucked it down earlier i cant seem to open car witht he thob only withthe key, had it on vag com and came up with 01365- internal central locking on B+ anyone else had this before?
philipwalker
RE: central locking problem after a monsoon in york
Post by philipwalker » Fri Sep 15, 2006 8:41 am
Do all the electric windows work correctly?? If they are ok it may need a key recode.
If the windows do not work it sounds like some water has got into the unit.
The central locking unit is located in the boot under the o/s rear light.
mikecmr
Post by mikecmr » Fri Sep 15, 2006 10:47 am
yeah all windows work fine i had a new drivers side rear light fitted a few weeks back do you think it could of leaked?
shineydave
Post by shineydave » Fri Sep 15, 2006 3:52 pm
does the central locking work when opening with the key, is anything else not working, ie, interior lights. if all is ok it might just need re-synching with the central locking controller by unlocking the car then pressing the button for about 5 seconds
mikecmr
Post by mikecmr » Fri Sep 15, 2006 3:58 pm
ok had it apart and looks like my new light has been leaking and there was around an inch of water where the central locking unit is, cleaned it all out blown the unot out with air vag-com says no errors but still not working correctly do you think its time for a new unit?
shineydave
Post by shineydave » Fri Sep 15, 2006 3:59 pm
they're sealed pretty well, gaskets etc in there, you might be lucky, as i said earlier, is everything else working ok?
mikecmr
Post by mikecmr » Fri Sep 15, 2006 4:06 pm
if i try to open the doors with the key i have to beat the car to open the door before it locks it again then i have to turn ingnition on and then open all doors by the switch on the door really stressing me out now haha.
yeah the units are tight but i noticed under one of the connectors lots of blue dust looked like it was a burnt capicator
MarkB
Post by MarkB » Fri Sep 15, 2006 4:13 pm
New unit me thinks. May even need to clean some of the connections if any are discoloured
Mark
Return to “Audi S and RS Ownership”
