MAF again
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
andy1234
MAF again
Post by andy1234 » Thu Jun 15, 2006 8:32 am
Feels like the MAF has gone on my car again for the 4th time in 6 months (this ones lasted 3 weeks).
symptoms are it feels like its not boosting properly, after 15/20 minuites of driving it goes onto safe boost , but if you kill the ignition and restart it again its comes out of this so no air leaks.
Apart from the MAFs being crap, is there anything else that could cause the MAF to go (earthing problem etc etc).
Also are the RS4 MAFs as crap, or are they a bit more resilient. And if an RS4 item were to be fitted do they give the same voltage per gms of air (so theres no need for any recalibrating). Sorry for all the questions, was just wondering if anyone else has anything similar.
Cheers!
Andy
my cars for sale :(
BaSen
RE: MAF again
Post by BaSen » Thu Jun 15, 2006 8:50 am
The RS4 MAF housing is somewhat bigger than the original S4 MAF so you'd have to change quite alot of stuf to fit it.
However there is another MAF to replace the weak BOSCH maf, Hitachi brand. It's more expensive, but lasts longer and less sensitive to dust etc. Haven't tried it myself yet since my new MAF seems to work nice enough. I'm running with an open air filter atm and it's still working properly after 10months usage.
Are you running open air filter or original air box?
Nogaroblue Saloon S4, RS4 clutch, B&M shortshifter, Rieger RS4 front bumper, Dahlback Racing DV's.
Coming soon: K04's, RS4 ic:s, Dahlback Racing custom engine remap, Dahlback Racing exhaust etc etc!
http://www.garaget.org/?car=3469
SimonS4MTM
RE: MAF again
Post by SimonS4MTM » Thu Jun 15, 2006 9:01 am
How do you know its your MAF
KayGee
RE: MAF again
Post by KayGee » Thu Jun 15, 2006 9:41 am
Do you have VAGCom if so post up the codes. Also log block 3. Sounds more like a boost leak causing turbos to overspin and ECU to drop you in limp mode.
andy1234
RE: MAF again
Post by andy1234 » Thu Jun 15, 2006 9:52 am
original box with JR panel filter.Good point about the Hitachi.Who supplys these?
I dont know 100% that its my MAF, but the car has developed faults consistent with when the MAF has failed before (bit flat to drive, not as flat as when on limp mode,just not quite the same).
No VAGcom.If there is anyone in cheshire/manchester who would mind spending 2 mins to take a log of whats going on id be very grateful. As far as boost leak goes, the car was only pressure tested bout 5/6 weeks ago by MRC. Not ruling a leak out entirely but think its unlikely as this fault has occured before when there have been no leaks.
my cars for sale :(
andy1234
RE: MAF again
Post by andy1234 » Thu Jun 15, 2006 9:53 am
oh, and thanks for your quick responses! :thumb:
my cars for sale :(
BaSen
RE: MAF again
Post by BaSen » Thu Jun 15, 2006 10:40 am
Now i only know a dealer in Sweden that houses these Hitachis but i'm sure there are plenty of dealers all around the world. :)
The price on the Hitachi MAF in Sweden is 2995:- SEK and 1£ is ~14:- SEK Yes a bit more expensive than the Bosch one but i believe it's worth the extra cost to switch.
SimonS4MTM
RE: MAF again
Post by SimonS4MTM » Thu Jun 15, 2006 11:08 am
This requires some wiring modifications and I am not even sure if the ecu will accept the Hitachi MAF
jimbogrey
Post by jimbogrey » Thu Jun 15, 2006 11:17 am
I have a similar problem and have changed most relevant parts the one part I havent changed is the N75 valve, if faulty could this generate these types of symptoms, without thrwing a fault code
Jimbo
ZeroK66
RE: MAF again
Post by ZeroK66 » Thu Jun 15, 2006 11:17 am
I thought you needed a newer ECU to use the Hitachi MAF? Thought you couldnt swap between the two?
jimbogrey
Jimbo
harry
Post by harry » Thu Jun 15, 2006 11:26 am
Thought i read somewhere that a non OEM panel filter can affect the MAF
Practise safe sex & drive a hybrid if you can...
BRETTCOLLINS
Post by BRETTCOLLINS » Thu Jun 15, 2006 11:54 am
Did run with an K & N panel filter for over 6 months with no problem. Been told that faulty DV's can kill air masses.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
andy1234
Post by andy1234 » Thu Jun 15, 2006 12:31 pm
DVs are fine afaik as they were only just pressure tested a short time a go and my cars chewed through MAFs before then. I can understand a K&N causing problems because the oil on the filter comes off and clogs the MAF from what ive heard, but the filter ive gots dry foam type (kind of like a pipercross).
@jimbo, got a spare N75 if you want me to post it you?
thanks for all your suggestions.Been looking at the VAGcom register to see if theres anyone in cheshire/manchester but i need to register or something so not having much luck?
my cars for sale :(
Dippy
Post by Dippy » Thu Jun 15, 2006 12:33 pm
To confirm the question - yes, to upgrade to a Hitachi MAF you need to modify the wiring AND get a new ECU.
2001 Silver S4 Avant
Users browsing this forum: Majestic-12 [Bot] and 45 guests
