MAF again
MAF again
Feels like the MAF has gone on my car again for the 4th time in 6 months (this ones lasted 3 weeks).
symptoms are it feels like its not boosting properly, after 15/20 minuites of driving it goes onto safe boost , but if you kill the ignition and restart it again its comes out of this so no air leaks.
Apart from the MAFs being crap, is there anything else that could cause the MAF to go (earthing problem etc etc).
Also are the RS4 MAFs as crap, or are they a bit more resilient. And if an RS4 item were to be fitted do they give the same voltage per gms of air (so theres no need for any recalibrating). Sorry for all the questions, was just wondering if anyone else has anything similar.
Cheers!
Andy
Cheers!
Andy
my cars for sale
RE: MAF again
The RS4 MAF housing is somewhat bigger than the original S4 MAF so you'd have to change quite alot of stuf to fit it.
However there is another MAF to replace the weak BOSCH maf, Hitachi brand. It's more expensive, but lasts longer and less sensitive to dust etc. Haven't tried it myself yet since my new MAF seems to work nice enough. I'm running with an open air filter atm and it's still working properly after 10months usage.
Are you running open air filter or original air box?
Nogaroblue Saloon S4, RS4 clutch, B&M shortshifter, Rieger RS4 front bumper, Dahlback Racing DV's.
Coming soon: K04's, RS4 ic:s, Dahlback Racing custom engine remap, Dahlback Racing exhaust etc etc!
http://www.garaget.org/?car=3469
- SimonS4MTM
- Top Gear
RE: MAF again
How do you know its your MAF
RE: MAF again
Do you have VAGCom if so post up the codes. Also log block 3. Sounds more like a boost leak causing turbos to overspin and ECU to drop you in limp mode.
RE: MAF again
original box with JR panel filter.Good point about the Hitachi.Who supplys these?Are you running open air filter or original air box?
I dont know 100% that its my MAF, but the car has developed faults consistent with when the MAF has failed before (bit flat to drive, not as flat as when on limp mode,just not quite the same).How do you know its your MAF
No VAGcom.If there is anyone in cheshire/manchester who would mind spending 2 mins to take a log of whats going on id be very grateful. As far as boost leak goes, the car was only pressure tested bout 5/6 weeks ago by MRC. Not ruling a leak out entirely but think its unlikely as this fault has occured before when there have been no leaks.Do you have VAGCom if so post up the codes. Also log block 3. Sounds more like a boost leak causing turbos to overspin and ECU to drop you in limp mode.
my cars for sale
RE: MAF again
Now i only know a dealer in Sweden that houses these Hitachis but i'm sure there are plenty of dealers all around the world.
The price on the Hitachi MAF in Sweden is 2995:- SEK and 1£ is ~14:- SEK Yes a bit more expensive than the Bosch one but i believe it's worth the extra cost to switch.
- SimonS4MTM
- Top Gear
RE: MAF again
This requires some wiring modifications and I am not even sure if the ecu will accept the Hitachi MAF
RE: MAF again
I thought you needed a newer ECU to use the Hitachi MAF? Thought you couldnt swap between the two?
BRETTCOLLINS
- 5th Gear
DVs are fine afaik as they were only just pressure tested a short time a go and my cars chewed through MAFs before then. I can understand a K&N causing problems because the oil on the filter comes off and clogs the MAF from what ive heard, but the filter ive gots dry foam type (kind of like a pipercross).
@jimbo, got a spare N75 if you want me to post it you?
thanks for all your suggestions.Been looking at the VAGcom register to see if theres anyone in cheshire/manchester but i need to register or something so not having much luck?
my cars for sale
To confirm the question - yes, to upgrade to a Hitachi MAF you need to modify the wiring AND get a new ECU.
2001 Silver S4 Avant
Users browsing this forum: Google [Bot] and 89 guests
