Throttle reset
Throttle reset
Is there anyway to reset the throttle on the S4 so it can learn my driving style?
RE: Throttle reset
Key in the ignition turn on but don't start, wait 10 to 15 secs, you'll here the TB re-align itself (easier with bonnet up).
RE: Throttle reset
Nice... thought that was what it was.
Anyone do/done this?
- SimonS4MTM
- Top Gear
RE: Throttle reset
Only with VAG-COM.
I thought you had to leave it longer than 10 to 15 secs
RE: Throttle reset
I'm sure its 30 secs at least.
It does not "learn your driving style" - all it does is motor the throttle and re-read the sensors so that it can properly control the throttle position.
2001 Silver S4 Avant
RE: Throttle reset
vag-com can reset your basic setting..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
RE: Throttle reset
What does Realigning the throttle do exactly.
Whats the advantage or point of doing this?
RE: Throttle reset
10-15 secs is how long it takes to start only takes 5-10 secs to complete. Resets throttle alignment and sets ECU settings back to defaults.
On VAGCom it is a push button labelled TBA or Throttle Body Adaption.
- confusionhunter
- confusionhunter
Thanks confusion... I can use that link now to learn how to use my VAG-Com
