Throttle reset
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
ZeroK66
Throttle reset
Post by ZeroK66 » Wed Apr 05, 2006 10:11 am
Is there anyway to reset the throttle on the S4 so it can learn my driving style?
KayGee
RE: Throttle reset
Post by KayGee » Wed Apr 05, 2006 10:35 am
Key in the ignition turn on but don't start, wait 10 to 15 secs, you'll here the TB re-align itself (easier with bonnet up).
ZeroK66
RE: Throttle reset
Post by ZeroK66 » Wed Apr 05, 2006 12:01 pm
Nice... thought that was what it was.
Anyone do/done this?
SimonS4MTM
RE: Throttle reset
Post by SimonS4MTM » Wed Apr 05, 2006 12:16 pm
Only with VAG-COM.
I thought you had to leave it longer than 10 to 15 secs
Dippy
RE: Throttle reset
Post by Dippy » Wed Apr 05, 2006 1:58 pm
I'm sure its 30 secs at least.
It does not "learn your driving style" - all it does is motor the throttle and re-read the sensors so that it can properly control the throttle position.
2001 Silver S4 Avant
s4woody
RE: Throttle reset
Post by s4woody » Wed Apr 05, 2006 2:03 pm
vag-com can reset your basic setting..
GARTH ROAD MOT CENTRE LTD
020 83353032
saf
RE: Throttle reset
Post by saf » Wed Apr 05, 2006 3:55 pm
What does Realigning the throttle do exactly.
Whats the advantage or point of doing this?
KayGee
RE: Throttle reset
Post by KayGee » Wed Apr 05, 2006 5:32 pm
10-15 secs is how long it takes to start only takes 5-10 secs to complete. Resets throttle alignment and sets ECU settings back to defaults.
Morpheous
Post by Morpheous » Wed Apr 05, 2006 8:19 pm
Not sure if Vag com allows it, but if you go into engine 01 adaption channel 0 it will ask if you want to delete (ECU)learnt values, select forward arrow on VAG 5052 0r 5051 all done.
You will need to set basic setting for throttle afterwards channel 60 on later cars.
KayGee
Post by KayGee » Thu Apr 06, 2006 3:42 am
On VAGCom it is a push button labelled TBA or Throttle Body Adaption.
confusionhunter
Post by confusionhunter » Thu Apr 06, 2006 8:30 am
Cha ching!:
http://www.ross-tech.com/vag-com/cars/audiB5.html
scroll about half a page down...
Mark.
confusionhunter
Post by confusionhunter » Thu Apr 06, 2006 8:32 am
Other than physical removal of the TB, are there any reason why you should need to do this?
Just incase? Or is it common for getting out of sync?
Mark.
ZeroK66
Post by ZeroK66 » Fri Apr 07, 2006 9:57 am
Thanks confusion... I can use that link now to learn how to use my VAG-Com :)
Return to “DTC / VCDS”
