Immobiliser
bobjebb
Immobiliser
Post by bobjebb » Wed Feb 08, 2006 11:40 am
I'm due to collect my car on Monday, and have learnt that it has had an additional immobiliser fitted, so thats all fine. However, Listers have no paperwork with it, and this includes a PIN to overide it. It's a Autowatch 171 PPI if any of you are experts!
These things in my experience always go wrong, and I'm fairly stuffed if I don't have instructions/PIN numbers etc.
Am I right to put the onus on the dealer to sort this out? I'd almost rather it wasn't there, but it's £150 to remove, and I ain't paying it!
Cheers for advice.
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
BigMo
RE: Immobiliser
Post by BigMo » Wed Feb 08, 2006 12:15 pm
Just tell them to remove it if you don't want it, but in any case, the onus is on the dealer. If they don't do as you ask, they lose a sale and a big commission at that one too.
RS6 (MRC'd with econodrive) is not just for Xmas
Toyota Aygo Platinum for minimising carbon footprint.
mwcltd
Post by mwcltd » Wed Feb 08, 2006 12:23 pm
Talk about belt and braces. The standard Audi immobiliser is pretty good. Check that your car has a tracker fitted as most insurance companies will not touch it without one. If you cannot get the information then the dealer should remove the extra immobiliser at his cost. Also, I suggest getting it reprogrammed for anti-hijack mode where one press on the unlock button only unlocks the drivers door, a further press unlocking all other doors. Also, when you lock the car it gives an audible warning. I had my dealer replace the drivers door handle with a blank one so the only lock is now on the tailgate, however this can be double locked. When our friendly teaa leaves look at my car and don't see a key hole they move to the next car.
bobjebb
Post by bobjebb » Wed Feb 08, 2006 1:41 pm
Thanks for the info chaps. I've had the necessary assurances. So do you mean the standard Audi system can be programmed to just open the drivers door first? as that would be something I'd like to do. Also interested in what you had done with the passenger door lock! Was it expensive?
A final question - the car does have a Tracker, according to the dealer, but I've no more info than that yet. Were these fitted as standard? (6+) If so what model was it?
Thanks again.
Back with C6 RS6
And again C7 RS6
SimonS4MTM
Post by SimonS4MTM » Wed Feb 08, 2006 2:23 pm
Sounds like you need to get onto the dealer about this to get things sorted out, I would want to see evidence from Tracker that it does have one fitted, get the dealer to speak to them direct.
I would deffinately get them to remove the imobilsier if they cannot give you a pin, free of charge of course.
They should also programe the locks FOC in my opinion.
Sold the RS4 yet?? Or are you trading it, if so what have they offered?
mwcltd
Post by mwcltd » Wed Feb 08, 2006 2:35 pm
Any Audi can be reporgrammed with the anti hijack facility. The RS6+ came with one door lock on the drivers door. My dealer fitted a rear offside door handle to the drivers door and now I have no door locks, only a tailgate lock which can be double locked.
bobjebb
Post by bobjebb » Wed Feb 08, 2006 3:24 pm
Thanks again all. Simon - sold the RS4, sad to see it go, all the way to Leeds! Dazp is the new owner and has joined the forum.
Back with C6 RS6
And again C7 RS6
mwcltd
Post by mwcltd » Wed Feb 08, 2006 3:43 pm
I forgot to mention that the anti hijack program also locks the doors when you go more than 10mph.
bobjebb
Post by bobjebb » Wed Feb 08, 2006 4:03 pm
Tracker Horizon fitted, just called them with chassis number. Anyone got this? Presume it's worth taking on the subscription?
Back with C6 RS6
And again C7 RS6
mwcltd
Post by mwcltd » Wed Feb 08, 2006 7:38 pm
I have tracker horizon fitted and yes, it is worth while keeping up with the subscription. This was fitted to the car from new and I went for the lifetime subscription option but I do not believe that it is transferable to a new owner.
Rich_C
Post by Rich_C » Wed Feb 08, 2006 8:58 pm
I personally think so. I actually paid up my subscription the day before I picked up my RS6 just in case ... (of what I'm not sure).
Anyway, mine has got the Tracker Monitor fitted. I got a call from Tracker last Friday to say the movement sensor on my car had triggered. After a moments panic I realised it was at Audi having it's service done. I'm presuming it must have activated when the technicians were lifting it up on the ramp. I'm quite re-assured that the technology works after that little incident.
Rich.
bobjebb
Post by bobjebb » Wed Feb 08, 2006 9:15 pm
Which reminds me:
"If a TRACKER Horizon equipped vehicle is illegally moved, a movement sensor hidden in the vehicle sends a signal to TRACKER HQ."
how do they know when it's being "illegally" moved?! :roll:
Back with C6 RS6
And again C7 RS6
Rich_C
Post by Rich_C » Wed Feb 08, 2006 10:03 pm
I presume if the cars motion sensor is activated without the key being in the ignition.
Rich.
peterb
Post by peterb » Thu Feb 09, 2006 1:06 am
All RS6 cars supplied through Audi UK had the option of a standard Tracker at zero cost. I paid to upgrade to Horizon.
The description of the 'anti-hijack' facility mentioned above is a little confused - it's actually three different features which can all be enabled independently:
1) Beep on locking
2) 2-stage unlocking (driver's door on first press, then rest of doors)
3) Lock on speed (all doors lock when the road speed reaches 15kph, and unlock when the key is removed form ignition)
On cars built up to July 2003, this latter feature is not reliable - it may not always activate. There is later firmware for the central locking controller which fixes it.
These features can all be enabled, very easily, with VAG-COM. If you come along to a Windsor meet (always last Wednesday of the month), I can do it for you.
Suzuki Carry 660
bobjebb
Post by bobjebb » Thu Feb 09, 2006 10:55 am
Thanks, judging by the owner's security conciousness I wouldn't be surprised if that's all been done already.
Back with C6 RS6
And again C7 RS6
Users browsing this forum: Google Adsense [Bot], skyegtb and 69 guests
