Audi S3 after the Big turbo upgrade - Video inside
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
S3rdias
Post by S3rdias » Tue Dec 20, 2005 12:51 am
This vid was taped yesterday...
Hope u like it :twisted: :twisted:
Right click and save as: http://www.audisclub.com.br/galeria/video/BTS3.wmv
A pic of the engine bay
gavinS3
Post by gavinS3 » Mon Dec 26, 2005 6:33 am
tuning list??
Ryan_s3
Post by Ryan_s3 » Sun Jan 01, 2006 12:48 pm
atp kit then,gt28?
Image360bhp 342lb/t
S3rdias
Post by S3rdias » Sun Jan 01, 2006 11:33 pm
Mods are:
- walbro inline fuel pump
- 440cc injectors
- 4 bar FPR
- Pagparts manifold
- GT2871R .64
- dual SMIC (larger than stock)
- custom piping
- 3´´ stainless steel DP
- 2,5´´ stainless steel exhaust ( cat removed)
- Autometer Ultralite vac/boost, FP, Oil temp and hallmeter gauges
- UNICHIP
Ryan_s3
Post by Ryan_s3 » Mon Jan 02, 2006 11:21 am
Would have thought you would have a need a swirl pot with a in-line pump.Do you have a power graph?
Image360bhp 342lb/t
S3rdias
Post by S3rdias » Mon Jan 02, 2006 7:36 pm
Dyno chart (engine power output).
This is just a schematic graph for easy view :wink:
Red line is before and blue line is after some tweaking :twisted:
Ryan_s3
Post by Ryan_s3 » Tue Jan 03, 2006 6:39 pm
Seems like quite a laggy turbo,to give you some indication i have 220 WHP at 3800rpm(260bhp engine power).What sort of boost are you running it at?
Yours comes on strong from 5,000rpm.Do you have a torque graph?
Image360bhp 342lb/t
S3rdias
Post by S3rdias » Tue Jan 03, 2006 8:56 pm
Well, I am hitting full boost (19psi) @ 4k rpm. I think that if I had taken it to 7k rpm I would get a better number :twisted: , but I was trying to keep it safe :roll: . If u compare my dyno to ATP GT2871R dyno u will notice that they look very similar :wink:
This one is APR Stage III + Audi TTQ
At what RPM do u get your peak HP?? Can your turbo hold the boost til redline?
Ryan_s3
Post by Ryan_s3 » Tue Jan 03, 2006 10:54 pm
peak power is at 6,000, the turbo can hold 1.6 bar till redline but i don't run it that hard other wise will blow the engine(standard internals).I run 1.5bar overboost to 1.35 redline this give a nice 300whp and 345lb/t.Spools up quick,not much lag.
Image360bhp 342lb/t
david7m
Post by david7m » Wed Jan 04, 2006 1:25 pm
@Ryan S3, what spec is your engine? I'm looking into increasing my bhp and wondered what the best route is.....any ideas on price too?
APR 270bhp S3, Mixer K6 750
Ryan_s3
Post by Ryan_s3 » Wed Jan 04, 2006 6:27 pm
Standard APY S3 engine with 20mm pins. Firstly david what sort of power are looking for?remap will net you 260bhp with 300lb/t torque.
Anything after this means new turbo,lines,manifold,injectors,sports cat and exhaust,downpipe,pipework.I'm running close to the edge at 360bhp 345lb/t(this is with other modifications aswell).After this you have to replace rods and valves,this should see 400bhp 380lb/t.After this sky's the limit,how deep are your pockets?
Image360bhp 342lb/t
david7m
Post by david7m » Thu Jan 05, 2006 1:45 pm
Ryan, I already have the APR software and a replacement air filter. Think its approx. 270bhp.
Not sure of the engine code on mine, but the car was a 2001 210bhp facelift version.
Another 100bhp sounds good to me.
Can you list all your mods and where it was done with prices please?
Have you changed the brakes?
PS My pockets are average size :wink:
david7m
Post by david7m » Thu Jan 05, 2006 1:47 pm
Oh, and another thing, my car has covered approx. 51k miles. Is this ok to mod at this mileage?
Soupie69uk
Post by Soupie69uk » Thu Jan 05, 2006 4:52 pm
I see you used the Dastek unichip.
How good did you find it? As i am thinking of using them as they can be updated pretty easily and cheaply.
Nice video btw!!
Ryan_s3
Post by Ryan_s3 » Thu Jan 05, 2006 7:20 pm
210's are either apy or amk,apy is the better of the two,although amk comes with me7.5 which has more safety features.
51k is fine,mine is on 48k.
I run porsche 993tt front brakes and uprated rear discs and pads.
My spec is pretty big but if you're after 380bhp,380lb/t
ihi vf34 p20(same as mine)
Manifold
rods ,valves,perhaps coat pistons
custom single intercooler
3" exhaust ,downpipe
Induction cone/kit with feed.
Injectors and fpr
I'm also running a uprated sachs clutch with uprated cover and plate.
this supplied and fitted is somewhere near 8-9k.
Image360bhp 342lb/t
Users browsing this forum: No registered users and 7 guests
