I need a new instrument cluster !!!
2.7 V6 30v biturbo - 380 bhp
prof
Post by prof » Sat Dec 03, 2005 4:35 pm
The guys fitting my ICE have arsed up the install and cracked the perspex on the instrument cluster.
Where can i get a second hand one for an RS4 or will a normal A4 one fit ??
the guys have not charged me for the ICE or the install, so if I can pick up a cluster for sensible money, I'm quids in.
also, will I have to get AUDI to reprogramme in the correct mileage or is this stored in the ECU ???
thanks,
prof
simple1
RE: I need a new instrument cluster !!!
Post by simple1 » Sat Dec 03, 2005 5:06 pm
You can get the cover without al the clocks... how did they manage to wipe the mileage, usually only can be done through Obd port
The other question there lies, what did they install ice with.......... No 7 hammer and Size 11 work boots???????????????
philipwalker
Post by philipwalker » Sat Dec 03, 2005 7:07 pm
You may have trouble getting one second hand. Normal A4 dashes may fit but dont go up to 200mph!!
The replacment is exchange from the dealer priced at (8D0 920 981X) £394+ vat. You will need to get this recoded by the dealer as you need the 16 digit skn number. It will lock out the ecu every time you attempt to start.
MK4ASH
Post by MK4ASH » Sat Dec 03, 2005 8:17 pm
Second hand dashes are not an option unless you can find one with the same mileage as your car. Once a mileage has been coded to a dash thats it, its there for good. unless of course you choose to use one of these "mileage correction" characters that stuff up the ecu anyway!!!
If it aint broke then dont try to fix it!
B5 RS4
MRC 420+Expired Precats
PCCB Calipers x4-B7 Discs x4
R8 Handbrake Calipers
Milltek
710N's
prof
Post by prof » Sun Dec 04, 2005 11:24 am
philipwalker,
are you saying that even if I can find a seconhand one, the ECU will not recognise it until it is recoded by AUDI ???
So basically my options are :-
Get a replacement screen.
Source a seceondhand unit and maybe get it recoded if this is required to make it work.
thanks,
prof
philipwalker
Post by philipwalker » Sun Dec 04, 2005 4:22 pm
Correct, the dash is part of the immobiliser it will need recoding to suit.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
bobjebb
Post by bobjebb » Sun Dec 04, 2005 4:33 pm
you forgot the 3rd option.... Make the ICE company sort it out! They must have some sort of insurance?
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
MK4ASH
Post by MK4ASH » Sun Dec 04, 2005 5:45 pm
I dont think Audi supply replacement screens but will find out tomorrow for definate. I havnt ever done it but i've looked at enough dashes and it may be possible to strip it down and just use the screen from a second hand dash.
Just in case you do choose the new option Audi charge an hours labour to fit and reprogramme a dash. Its all now done over the internet.
Ash
B5 RS4
Milltek
710N's
HGH
Post by HGH » Sun Dec 04, 2005 11:22 pm
You can buy a second-hand one, and switch the cluster.
Because i think that only the inside instruments are different.
docurley
Post by docurley » Thu Dec 08, 2005 1:59 pm
You could use the binnacle of the A4 or buy one from Audi, as the clocks will separate from the clocks them selves.
How to take the clocks out
http://www.audiworld.com/tech/int43.shtml
