I need a new instrument cluster !!!
The guys fitting my ICE have arsed up the install and cracked the perspex on the instrument cluster.
Where can i get a second hand one for an RS4 or will a normal A4 one fit ??
the guys have not charged me for the ICE or the install, so if I can pick up a cluster for sensible money, I'm quids in.
also, will I have to get AUDI to reprogramme in the correct mileage or is this stored in the ECU ???
thanks,
prof
thanks,
prof
RE: I need a new instrument cluster !!!
You can get the cover without al the clocks... how did they manage to wipe the mileage, usually only can be done through Obd port
The other question there lies, what did they install ice with.......... No 7 hammer and Size 11 work boots???????????????
philipwalker
- 5th Gear
You may have trouble getting one second hand. Normal A4 dashes may fit but dont go up to 200mph!!
The replacment is exchange from the dealer priced at (8D0 920 981X) £394+ vat. You will need to get this recoded by the dealer as you need the 16 digit skn number. It will lock out the ecu every time you attempt to start.
Second hand dashes are not an option unless you can find one with the same mileage as your car. Once a mileage has been coded to a dash thats it, its there for good. unless of course you choose to use one of these "mileage correction" characters that stuff up the ecu anyway!!!
If it aint broke then dont try to fix it!
B5 RS4
MRC 420+Expired Precats
PCCB Calipers x4-B7 Discs x4
R8 Handbrake Calipers
Milltek
710N's
B5 RS4
Milltek
710N's
philipwalker
- 5th Gear
I dont think Audi supply replacement screens but will find out tomorrow for definate. I havnt ever done it but i've looked at enough dashes and it may be possible to strip it down and just use the screen from a second hand dash.
Just in case you do choose the new option Audi charge an hours labour to fit and reprogramme a dash. Its all now done over the internet.
Ash
Ash
B5 RS4
Milltek
710N's
B5 RS4
Milltek
710N's
You could use the binnacle of the A4 or buy one from Audi, as the clocks will separate from the clocks them selves.
How to take the clocks out
http://www.audiworld.com/tech/int43.shtml
Users browsing this forum: No registered users and 156 guests
