sat nav
lengster1
sat nav
Post by lengster1 » Mon Nov 07, 2005 2:06 pm
hi found a sat nav system for sale. part no 4B0035192k.
Does any one know if this will fit in an RS4 ??? Cheers !
peterb
RE: sat nav
Post by peterb » Mon Nov 07, 2005 2:30 pm
That's the A6 fitment, so I think that the faceplate would need trimming to fit in the 4. Other than that, it will be okay.
Suzuki Carry 660
HGH
RE: sat nav
Post by HGH » Tue Nov 08, 2005 12:03 am
If it's an rns-e or dvd navi it will fit,but you must do a lot of rewiring.
Because the iso connectors won't fit.
peterb
Re: RE: sat nav
Post by peterb » Tue Nov 08, 2005 12:31 am
HGH wrote:If it's an rns-e or dvd navi...
No, the 'k' is the older, CD-based, RNS 4 system (often referred to as a Navi D).
It will still require some wiring changes to fit. To fully integrate the unit, it will be necessary to instal a TMC module too.
If the RS4 uses CAN bus (I guess that it does), it may well be simpler to install an RNS-E - the wiring adapters are readily available, making it almost plug'n'play, and the TMC module is not then required.
Suzuki Carry 660
lengster1
RE: Re: RE: sat nav
Post by lengster1 » Sat Nov 12, 2005 11:28 pm
Thanks guys my local dealer also thought it was an a6 unit so i didnt pursue it
Return to “Electrical”
