hi found a sat nav system for sale. part no 4B0035192k.
Does any one know if this will fit in an RS4 ??? Cheers !
sat nav
RE: sat nav
That's the A6 fitment, so I think that the faceplate would need trimming to fit in the 4. Other than that, it will be okay.
07 Mitsubishi Pajero(Shogun) 3.2 Di-D
Suzuki Carry 660
Suzuki Carry 660
RE: sat nav
If it's an rns-e or dvd navi it will fit,but you must do a lot of rewiring.
Because the iso connectors won't fit.
Re: RE: sat nav
No, the 'k' is the older, CD-based, RNS 4 system (often referred to as a Navi D).HGH wrote:If it's an rns-e or dvd navi...
It will still require some wiring changes to fit. To fully integrate the unit, it will be necessary to instal a TMC module too.
If the RS4 uses CAN bus (I guess that it does), it may well be simpler to install an RNS-E - the wiring adapters are readily available, making it almost plug'n'play, and the TMC module is not then required.
Suzuki Carry 660
Suzuki Carry 660
RE: Re: RE: sat nav
Thanks guys my local dealer also thought it was an a6 unit so i didnt pursue it
Users browsing this forum: No registered users and 46 guests
