Audi Software
Audi Software
Hi all
Does anyone know if Audi have done something clever with there software regards to servicing intervals my S4 has been running lovely over the past few months up until the service reminder came up on my dash. The car now doesn’t seem to pull as well as it did. I wondered if they done this so you would take it to the dealer
Am I just being stupid or is it something else?
Get VAG-COM. If you are really skint then I can sell you an older cable and you can use the shareware version for doing a lot of checks.
2001 Silver S4 Avant
- SimonS4MTM
- Top Gear
True, mine rang me and asked why I thought the MAF was duff because their check was OK, they test at tickover or something similar IIRC.SimonS4MTM wrote:You would be lucky if a dealer can diagnose a faulty MAF
I just said max should be 213 g/sec and mine read 140 AND I had lean DTC's for both cylinder banks.
I put my knowledge down to the power of asking questions on web forums
The Dealer said he thought the MAF was duff after a test drive but needed to check it on the computer. He also said the N75 Valve needed changing. I used to have the ESP light flicker on acceleration and it would cut the power. I'm going to take it back and see what they can do. If the MAF has gone duff again they should replace it under guarantee as it was only changed 5 months ago. (or would they?)You would be lucky if a dealer can diagnose a faulty MAF
Nice poem Dazzer
