Audi Software
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
S4PJH
Audi Software
Post by S4PJH » Mon Sep 26, 2005 7:29 pm
Hi all
Does anyone know if Audi have done something clever with there software regards to servicing intervals my S4 has been running lovely over the past few months up until the service reminder came up on my dash. The car now doesn’t seem to pull as well as it did. I wondered if they done this so you would take it to the dealer
Am I just being stupid or is it something else?
dazzer
Post by dazzer » Mon Sep 26, 2005 7:51 pm
Must be coincidence. The MAF and DVs are a weak point on the car - could be your problem.
S4PJH
Post by S4PJH » Mon Sep 26, 2005 8:40 pm
I have got forge DV and i had the MAF & N75 changed about 5 months ago.
dazzer
Post by dazzer » Tue Sep 27, 2005 12:57 pm
May be something else or could be the MAF again - only takes a bit if dirty air.
You really need VAG COM hooked up. What area of the country are you - may be some kind soul will help you with VAG COM.
S4PJH
Post by S4PJH » Tue Sep 27, 2005 7:13 pm
I'm in the West Midlands area near the NEC i need to goto the stealers to book it in for a service so i might get them to do a health check. It might be in my head, maybe i'm getting used to the car's performance. Maybe i need to chip it :idea:
Dippy
Post by Dippy » Wed Sep 28, 2005 1:16 am
Get VAG-COM. If you are really skint then I can sell you an older cable and you can use the shareware version for doing a lot of checks.
2001 Silver S4 Avant
dazzer
Post by dazzer » Wed Sep 28, 2005 12:39 pm
Get it chipped and get a free health check at the same time - well it's free if you go to MRC - actually that last bit rhymes - I'm a poet and I didn't know it :roll:
SimonS4MTM
Post by SimonS4MTM » Wed Sep 28, 2005 12:42 pm
You would be lucky if a dealer can diagnose a faulty MAF
DavidT
Post by DavidT » Wed Sep 28, 2005 1:45 pm
SimonS4MTM wrote:You would be lucky if a dealer can diagnose a faulty MAF
True, mine rang me and asked why I thought the MAF was duff because their check was OK, they test at tickover or something similar IIRC.
I just said max should be 213 g/sec and mine read 140 AND I had lean DTC's for both cylinder banks.
I put my knowledge down to the power of asking questions on web forums :-)
S4PJH
Post by S4PJH » Wed Sep 28, 2005 6:14 pm
The Dealer said he thought the MAF was duff after a test drive but needed to check it on the computer. He also said the N75 Valve needed changing. I used to have the ESP light flicker on acceleration and it would cut the power. I'm going to take it back and see what they can do. If the MAF has gone duff again they should replace it under guarantee as it was only changed 5 months ago. (or would they?)
Nice poem Dazzer :o
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 19 guests
