ETKA 6.0 help required
JohnW
Post by JohnW » Thu Mar 24, 2005 11:53 pm
Can someone who has a copy of ETKA 6 check which car a gearbox with code GHA is fitted to please (you can look the codes up in the transmission table - their not listed in ETKA 5 though).
Also if you would be able to confirm the gear ratios for that one and also an FYA.
Many thanks.
Cheers,
John.
simple1
RE: ETKA 6.0 help required
Post by simple1 » Fri Mar 25, 2005 12:58 am
John
If you put the codes into the table, it throws out GHA as GH, so no match but indicates a Golf box
Put in FYA and it gives FYF, Audi A4 S6 pre 09/01
Not much help I am sure :bash: If you have PC anywhere, dial in to mine and have a look for yourself. :roll:
JohnW
Post by JohnW » Sun Mar 27, 2005 9:54 pm
Hi Simon, thanks for looking.
you sure that's with ETKA6 ??
Reason I ask is that FYA is defo the correct ocde - I have a picture of the gearbox showing the number/code !
Cheers,
John.
p.s. got pc anywhere at work, but not loaded it here (yet ;) )
sitas3
Post by sitas3 » Sun Mar 27, 2005 10:51 pm
on my version, gearbox code FYA fitted to A4 between 06 2003 and 11 2003 - my other system confirms this as a B6 A4 1.9 TDI
The gearbox code GHA was fitted to A4 between 06 2003 and 12 2003 - also fitted to the Passat.
Both are 6 speed manual boxes.
Hope this helps
JohnW
Post by JohnW » Mon Mar 28, 2005 12:14 am
Thanks Simon.
See you guys on Tuesday (unless your staying over on Monday night) :beerchug:
Return to “General Car Chat”
