Can someone who has a copy of ETKA 6 check which car a gearbox with code GHA is fitted to please (you can look the codes up in the transmission table - their not listed in ETKA 5 though).
Also if you would be able to confirm the gear ratios for that one and also an FYA.
Many thanks.
Cheers,
John.
ETKA 6.0 help required
Too many toys, not enough time
RE: ETKA 6.0 help required
John
If you put the codes into the table, it throws out GHA as GH, so no match but indicates a Golf box
Put in FYA and it gives FYF, Audi A4 S6 pre 09/01
Not much help I am sure
If you have PC anywhere, dial in to mine and have a look for yourself.
Hi Simon, thanks for looking.
you sure that's with ETKA6 ??
Reason I ask is that FYA is defo the correct ocde - I have a picture of the gearbox showing the number/code !
Cheers,
John.
p.s. got pc anywhere at work, but not loaded it here (yet
Cheers,
John.
on my version, gearbox code FYA fitted to A4 between 06 2003 and 11 2003 - my other system confirms this as a B6 A4 1.9 TDI
The gearbox code GHA was fitted to A4 between 06 2003 and 12 2003 - also fitted to the Passat.
Both are 6 speed manual boxes.
Hope this helps
Hope this helps
Thanks Simon.
See you guys on Tuesday (unless your staying over on Monday night)
Users browsing this forum: No registered users and 89 guests
