Idle problem
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
davs4
Idle problem
Post by davs4 » Fri Jan 21, 2005 11:55 pm
Help, Car started today and idle went erratic, revs fluctuating and engine hunting! Is this a MAF failure symptom? Don't have a VAG-COM
JonnyX
RE: Idle problem
Post by JonnyX » Mon Jan 24, 2005 11:43 am
Sound like throttle body. Get an alignment done by someone with VAG-COM.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
davs4
RE: Idle problem
Post by davs4 » Mon Jan 24, 2005 6:17 pm
Ok, Thanks will try VAG-COM.Do you know if the plug change I did could cause this?
JonnyX
RE: Idle problem
Post by JonnyX » Mon Jan 24, 2005 6:32 pm
Well, if you changed the plugs and it started doing it straight after then it's a good bet that it's related.
Don't want to sound patronising but did you put it all back together properly (i.e. you didn't have one
of those ephipanies where you have some 'pieces left over'). Things to check here are:
plugs correct type.
Correct coil on each plug and fitted properly.
Sensor wiring reconnected properly - I assume you removed the airbox and MAF. Hunting could be dodgy
MAF input.
Did it give you are warning? (i.e. big, red, flashing ((!)) )
As a first step I would recommend seeing if there are any fault codes.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
daveweld
Post by daveweld » Mon Jan 24, 2005 6:43 pm
is it dodgy fuel?
are u running optimax or 95ron.
i had hunting problem on 95ron
regards
dave
davs4
Post by davs4 » Mon Jan 24, 2005 8:40 pm
No bits left over!! all replaced securely and correct VAG plugs used, problem started 2 weeks after fitment . I suspected MAF could be the cause owing to the inherent failure of these items, will check input plug-to be sure.
BTW Dave didn't fill with Optimax recently as they had run out,so had to use 95 Ron I will try and use then re-fill with Optimax
KayGee
Post by KayGee » Mon Jan 24, 2005 10:23 pm
I'm in Aylesbury during the week and have Vag Com. Ping me a PM if you want to meet up. Unplug the MAF see if this cures it, I suspect not.
tartan_rob
Post by tartan_rob » Tue Jan 25, 2005 10:19 am
I'm in Swindon too if you want to pop over and hook upto VAG-COM. Drop me a mail on robbie_beaton@dell.com if you want.
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
davs4
Post by davs4 » Tue Jan 25, 2005 9:46 pm
Thanks KayGee YGM
tartan_rob
Post by tartan_rob » Thu Jan 27, 2005 4:26 pm
Dave - sorry we could not fix your car....here is the detail of the fault code:
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 C
Component: 2.7l V6/5VT 01 0002
Coding: 05611
Shop #: WSC 00696
1 Fault Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
ALL - any idea why when we cleared engine fault codes (4 or 5 of them) the car went into limp mode and appeared to have a misfire? Also on idle, Dave's timing was around 20deg BTDC....my car was showing approx 7 deg BTDC and was running well.
2017 Kawasaki Z1000
2014 RS6
2014 S1
davs4
Post by davs4 » Thu Jan 27, 2005 6:31 pm
Top Man Rob, thanks for all your help.
p.s mile later car died completly, had to unplug MAF to get home,which restored full power Weird !!!
Thanks again buddy
KayGee
Post by KayGee » Thu Jan 27, 2005 9:04 pm
Time for a call to VAGParts for a recon MAF.....
davs4
Post by davs4 » Thu Jan 27, 2005 9:45 pm
Replace broken MAF plug <£2 new MAF Stealer price £70 + part ex old MAF.Will try new plug first
tartan_rob
Post by tartan_rob » Fri Jan 28, 2005 8:37 am
Dave - pleased to hear you got home....have no idea how the car ran though. My car would not run past about 2k revs if the MAF was not connected.....
Easy fix though.... :D :D
2017 Kawasaki Z1000
2014 RS6
2014 S1
KayGee
Post by KayGee » Fri Jan 28, 2005 8:49 pm
Mine runs OK with the MAF diss connected (someone suggested this to me when I was having a problem with the previous chip. OK as a short term get you home option.
