Idle problem
Idle problem
Help, Car started today and idle went erratic, revs fluctuating and engine hunting! Is this a MAF failure symptom? Don't have a VAG-COM
RE: Idle problem
Sound like throttle body. Get an alignment done by someone with VAG-COM.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
RE: Idle problem
Ok, Thanks will try VAG-COM.Do you know if the plug change I did could cause this?
RE: Idle problem
Well, if you changed the plugs and it started doing it straight after then it's a good bet that it's related.
Don't want to sound patronising but did you put it all back together properly (i.e. you didn't have one
of those ephipanies where you have some 'pieces left over'). Things to check here are:
plugs correct type.
Correct coil on each plug and fitted properly.
Sensor wiring reconnected properly - I assume you removed the airbox and MAF. Hunting could be dodgy
MAF input.
Did it give you are warning? (i.e. big, red, flashing ((!)) )
As a first step I would recommend seeing if there are any fault codes.
plugs correct type.
MAF input.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
No bits left over!! all replaced securely and correct VAG plugs used, problem started 2 weeks after fitment . I suspected MAF could be the cause owing to the inherent failure of these items, will check input plug-to be sure.
BTW Dave didn't fill with Optimax recently as they had run out,so had to use 95 Ron I will try and use then re-fill with Optimax
I'm in Aylesbury during the week and have Vag Com. Ping me a PM if you want to meet up. Unplug the MAF see if this cures it, I suspect not.
tartan_rob
I'm in Swindon too if you want to pop over and hook upto VAG-COM. Drop me a mail on robbie_beaton@dell.com if you want.
Rob
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
tartan_rob
Dave - sorry we could not fix your car....here is the detail of the fault code:
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 C
Component: 2.7l V6/5VT 01 0002
Coding: 05611
Shop #: WSC 00696
1 Fault Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
ALL - any idea why when we cleared engine fault codes (4 or 5 of them) the car went into limp mode and appeared to have a misfire? Also on idle, Dave's timing was around 20deg BTDC....my car was showing approx 7 deg BTDC and was running well.
Coding: 05611
Shop #: WSC 00696
1 Fault Found:
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Time for a call to VAGParts for a recon MAF.....
tartan_rob
Mine runs OK with the MAF diss connected (someone suggested this to me when I was having a problem with the previous chip. OK as a short term get you home option.
