Why's my car so slow!
RobTheHungryMonkey
A couple of weeks ago, I put some inferior petrol in the car and I noticed that it was significantly slower than before. I blamed the petrol, and after a couple of tanks of Optimax, was back to normal. But since then it has happened again?! This time on the same tank that it was performing well on!
It has only been fed Optimax since. So I'm assuming it's not the petrol. I also can't see how anything can be broken as it went from not working, to working fine for a while and then back again.
Anyone have any ideas?
RobTheHungryMonkey
maf through logging data only, as it only gives ann error through total failure..
or some people run the car for a short run with it disconnected and see if it improves..
you can get a service exchange item from some audi dealerships at circa 70-90 quid.
Coolant sensor gives a fault code... but maybe not a fault light.
Mafs can be erratic, ive been lucky and never had a problem in my 2 s3's
Definately sounds like the MAF. Take off the 4 pin connector and give it a try for a couple of days. It wont do any harm. The ECU will recognise its not getting a signal and go in to a preset mode and the engine will run normally. A coolant temp sensor fault is an option but no where near as common as the air flow sensor.
Ash
Ash
If it aint broke then dont try to fix it!
B5 RS4
MRC 420+Expired Precats
PCCB Calipers x4-B7 Discs x4
R8 Handbrake Calipers
Milltek
710N's
B5 RS4
Milltek
710N's
RobTheHungryMonkey
RobTheHungryMonkey
Users browsing this forum: No registered users and 92 guests
