Why's my car so slow!
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
RobTheHungryMonkey
Post by RobTheHungryMonkey » Wed Dec 08, 2004 3:37 pm
A couple of weeks ago, I put some inferior petrol in the car and I noticed that it was significantly slower than before. I blamed the petrol, and after a couple of tanks of Optimax, was back to normal. But since then it has happened again?! This time on the same tank that it was performing well on!
It has only been fed Optimax since. So I'm assuming it's not the petrol. I also can't see how anything can be broken as it went from not working, to working fine for a while and then back again.
Anyone have any ideas?
Paul-RS
Post by Paul-RS » Wed Dec 08, 2004 4:14 pm
MAF or coolant sensor are possibly culprets. they both can feck up fueling, hence performance..
RobTheHungryMonkey
Post by RobTheHungryMonkey » Wed Dec 08, 2004 5:01 pm
How would i go about testing these?
Would this be the case even though it went from slow, to working fine (for a week) and back to slow again?
Paul-RS
Post by Paul-RS » Wed Dec 08, 2004 10:51 pm
maf through logging data only, as it only gives ann error through total failure..
or some people run the car for a short run with it disconnected and see if it improves..
you can get a service exchange item from some audi dealerships at circa 70-90 quid.
Coolant sensor gives a fault code... but maybe not a fault light.
Mafs can be erratic, ive been lucky and never had a problem in my 2 s3's
bjacks
Post by bjacks » Thu Dec 09, 2004 9:17 am
Sounds like you'd be wise to reset the ECU. This will allow the car to adapt to the fuel again with any luck. Do a search on this as there are many theories on how to reset the ECU.
Ben
MK4ASH
Post by MK4ASH » Thu Dec 09, 2004 10:47 pm
Definately sounds like the MAF. Take off the 4 pin connector and give it a try for a couple of days. It wont do any harm. The ECU will recognise its not getting a signal and go in to a preset mode and the engine will run normally. A coolant temp sensor fault is an option but no where near as common as the air flow sensor.
Ash
If it aint broke then dont try to fix it!
B5 RS4
MRC 420+Expired Precats
PCCB Calipers x4-B7 Discs x4
R8 Handbrake Calipers
Milltek
710N's
RobTheHungryMonkey
Post by RobTheHungryMonkey » Tue Jan 18, 2005 4:48 pm
Thanks people, it was the MAF, and runs much better now. Still not as quick as it should be though. How can I reset the ECU?
MK4ASH
Post by MK4ASH » Tue Jan 18, 2005 11:22 pm
You need to use vag com or one of thw Audi diag machines. If your in Guildford at some point i'll do it for you!
07815 120363
B5 RS4
Milltek
710N's
RobTheHungryMonkey
Post by RobTheHungryMonkey » Wed Jan 19, 2005 3:42 pm
Am near Brighton, but have a freind in Farnborough. If i'm up that way I might take you up on that.
Thanks for the help, appreciated.
JonnyX
Post by JonnyX » Wed Jan 19, 2005 4:10 pm
Try disconnecting the battery neutral and leave it for a few minutes.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Nige_RS4
Post by Nige_RS4 » Wed Jan 19, 2005 5:48 pm
Or unplug the ECU!
Seriously though, you should always clear down any fault codes that exist (and they will if you disconnect the battery or unplug the ECU) You will need VAG-COM to do this.
Nige.
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: No registered users and 23 guests
