Drivers Display showing "Door Open"
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
993vic
Post by 993vic » Tue Oct 26, 2004 1:50 pm
About 1 in 10 start-ups result in the computer picture showing Drivers Door Open - when it is not! Sometimes it goes away when I slam the door shut again - sometimes not.
I guess its a faulty switch, but I can't see where it is? :oops: (Nothing obvious on the A-Pillar) Any ideas?
TIA
Vic
bazza
Post by bazza » Tue Oct 26, 2004 3:33 pm
i had this problem.
the door catch had to be replaced, i think the total bill was around £120, if you got warranty then you should claim off that.
Bazza
Past: Noggy 2000 B5 S4
Azure Blue 2000 Oettinger B5 S4
Mugello RS6 *STOLEN* RN52 UXB
Avus Oettinger A3 2.0T
Misano Oettinger C5 RS6
Phantom Oettinger C6 A6 Sline Avant
Present: RS7 Panther Black
Porsche Cayenne
C7 Avus silver avant 2.0 tdi ultra
Tomson
Post by Tomson » Tue Oct 26, 2004 3:55 pm
I have the same on the RS4, i also have one side of the boot squeezy piece that is broken, only opens on one side
993vic
Post by 993vic » Wed Oct 27, 2004 9:21 am
Thanks Bazza,
Time to test out the warranty then!
Dippy
Post by Dippy » Wed Oct 27, 2004 1:55 pm
Tomson wrote:I have the same on the RS4, i also have one side of the boot squeezy piece that is broken, only opens on one side
Same here. I fixed mine recently as I had the trim off recently to change my antenna amps. All I did was remove and replace the tiny connector and now it works. So must've been a dirty connector.
Also my hatch still plays up occasionally so I'll back-up the sentiment that if you have a warranty, get the catch replaced, because simply squirting WD40 in (what I did) doesn't provide a permanent fix...
2001 Silver S4 Avant
RobTheHungryMonkey
Post by RobTheHungryMonkey » Wed Oct 27, 2004 2:31 pm
Is there much you can do (if it's out of warranty) and you don't wantto take the trim off?
Dippy
Post by Dippy » Wed Oct 27, 2004 2:38 pm
Vibration 'may' clear it, so try some light tapping with a rubber hammer. Also try squirting some WD40 into the catch.
Users browsing this forum: Majestic-12 [Bot] and 85 guests
