ECU change
ECU change
Hi
Can someone tell me what will hapen if i change the ECU of my car with ASJ Engine with my friends ECU that is Build for AZR motor but has upgrade to 430Hp . Can we just do this ?????
Thanks so far
I Know that when you change the ECU that you have to typ in the old ECU code and you do need this VAG 15.. someting for it . But other then that is there anything else i have to watch ?? ASJ or AZR can the ECU just be switched ??? The tuners better to say MTM and sportec and so on do they have 2 diffrent program for the RS4 ??? one for AZR motor and one for ASJ ?????
I wouldn't recommend it. WHy not contact the tuner who did the map on the chipped ECU?
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Are you are sure the 2 ECU's are interchangeable and compatible with each engine code....? Usually a change in engine code signifys something significant eg an additional air injection system
Here is the procedure anyway http://www.ross-tech.com/vag-com/cars/I ... pping.html
there are differences in the emission control and monitoring systems between the two ECU/engine codes. Although Audi say that technically the physical engines are the same.
I'd say really that it may not be practical to be using an ecu designed for a different RS4 engine code, however I'm aware of one or more people doing just that!.
Users browsing this forum: jdp and 82 guests
